Old 09-04-2003, 10:52 PM
mattlenderman mattlenderman is offline
CD PLAYER Problem
i just installed a sony cd player. for some reason when i cut the car off, then i cut it back on, the time resets and all the stations i programed get reset. what could be causing this?? thanks for any help
Old 09-04-2003, 11:44 PM
k67p67 k67p67 is offline
What model head unit? What model car? Did you use a wire harness? What other equipment are you running? If you want help, provide more info.
SoundDomain link (system pics)
~ALL SHOW - NO GO~
Old 09-05-2003, 01:28 PM
sorry. the unit is cdx-m600. no i'm running no other equipment.yes i used a wire harness. the car is a 92' accord lx 4door. it works fine when the car is on. turn it off, then back on, the whole cd player gets reset. thanks for any info
Old 09-05-2003, 02:00 PM
First thing to check would be the 12V+ wire (yellow). Use a DMM and check to make sure that there is sufficient voltage present at all times (including during cranking).
~ALL SHOW - NO GO~
Old 09-05-2003, 05:26 PM
ok not sure what a DMM is. but i do know is i grounded the black wire, matched all the speaker wires, etc. could u eliberate a little on where the red,yellow,wires go? maybe somewhere in those 3 i messed up. thanks
Old 09-05-2003, 08:57 PM
(D)igital (M)ulti(m)eter. You said you used a wire harness. If that's true, there should have been no guesswork. You match up all the colors.
Yellow = 12V+ battery (constant)
Red = 12V+ switched ignition
Black = Ground
Blue/White = Remote turn-on
Blue = Power antenna lead
Orange or Orange/White = Illumination
Gray = RF +
Gray/Black = RF -
White = LF +
White/Black = LF -
Violet = RR +
Violet/Black = RR-
Green = LR +
Green/Black = LR -
~ALL SHOW - NO GO~
Old 09-06-2003, 01:28 AM
thanks for your help man. yea im kinda a newbie at this and just was trying to figure out what i did wrong. i know i left the power antenna unhooked because i have no power antenna. i just didnt know if i needed to tie in like a yellow wire in with the red, or orange, or whatever. evidentally ive done something thats causing this problem. i guess now my biggest thing i need to do is try taking the radio back out, and then check it out. when i get a little more idea on exacly what i did ill post it. thanks for your help again
matt
Old 09-06-2003, 11:01 AM
Again, check the yellow wire. It shouldn't be tied in with the red. One is constant power to preserve the memory and the other provides power and turns the HU off when the ignition is off.
~ALL SHOW - NO GO~
Old 09-07-2003, 12:45 AM
HA i see where the problem was. (see this was a used harness someone had gave to me off their sony radio which was in their honda) i took it apart and for some reason the had the yellow wire from the cd player connected in with the 2 red...BUT, the weird thing is on the harness, where the yellow wire should be it wasnt there! and u could kinda see where it looked like it got ripped out. So i had to put on my thinking cap and i figured out a solution. first i undid the yellow with the red and put the 2 reds together. then, i got a peice of a wire, crimped it to the end of the yellow wire, and at the other end ran the wire through the harness, into the (factory harness) directly. after firmly closing the harnesses together, i then added some super glue so the wire wouldnt come loose, turned it on, and it works like a champ! i'm not sure if u quite understand what i did, but all i know is i rigged it up and it works! thanks alot for your help man, otherwise i would have probabaly gotten agervated and paid to have it fixed. thanks !
MATT-
Old 09-07-2003, 01:37 AM
Glad to be of assistance. We all had to learn somewhere.
~ALL SHOW - NO GO~
