Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 09-04-2003, 09:04 PM
GlassPack GlassPack is offline
No Offense
Hey
First off i would like to say no offence to all the big rotary fans out there.
I have used a rotary engine for many years and for some odd reason they went out of style where i am located. Nobody where i live can do much work on them other than maybe change the oil (which I can do myself). Nobody seems to no anything about them anymore. What I have decided to do is go from rotary to piston in my RX-7 and I am looking for some honesty on an engine that would fit in the engine bay of an RX-7 with more or the same amount of power the rotary engine would put out. I have been told a Supra engine but what would be the best piston engine to fit an RX-7 with.
Thanks
P.S. I love rotarys, but it is getting to cost to much to have to drive 8 hours to get a head gasket or seal replaced.
Old 09-05-2003, 09:27 AM
GundamExpo's Avatar
GundamExpo GundamExpo is offline
First off, I think its going to be really hard to get near the power to displacement ratio that the rotary engine has. I dont know too much about motors, so it would be great if an expert could tell me if im on track or not. Anyway, what about an S2000 motor?
Old 09-05-2003, 12:39 PM
Barwick Barwick is offline
Re: No Offense
Originally Posted by GlassPack
Hey
Thanks
Why do you need someone to do work on the "rotary"? The only time someone touches the inside of the engine is when it gets rebuilt. Every single other thing is the exact same as a piston engine.
'90 RX-7 Turbo
$3000 buying and fixing = 13.75 @ 104.8 mph & outhandles most cars on the road. Not bad for $3000.
Old 09-05-2003, 03:09 PM
GundamExpo's Avatar
Just a guess...
Perhaps hes worried about the engine requiring a rebuild when nobody in his area is capable of performing the task.
Old 09-05-2003, 04:42 PM
banditkiller banditkiller is offline
Send a message via AIM to banditkiller
he might have been thinking that.....either way ....if you are going to go with a piston engine.....best bet to do what everyone else does...unless you like being a little different....then go with the supra engine.....it wil be harder ...but with money anything can be accomplished.....ford 302 v-8's drop in with an engine cradle made by grannys...they do alot of v6 and v-8 swaps for rx-7's....if i can find the link i will post it...best bet is to search through some older threads till you find the one about swapping in the v-8...now keep in mind you will also want a new rear....if at least new axles...302's are pretty cheap.....and can make good power....look at getting an aod...or a 5spd..but your trans wont mount to the v-8 if you so chose to do so....and even if it did....it would be toast within a few days......but either way i hope this helped a little bit....also chevy motors have a tendency of being dropped into rx-7's ...grannys also makes kits for lt-1's ls-1's and so fourth...the best of luck to you
Old 09-05-2003, 04:45 PM
http://members.tripod.com/~grannys/ and there is that link...doubnt it will work....it was a lazy cut and paste....
Old 09-05-2003, 06:31 PM
dayna240sx's Avatar
dayna240sx dayna240sx is offline
Banned
Send a message via AIM to dayna240sx
Rebuilding a rotary engine is not that difficult. If a 20 year old female can do it, I think you should be able to give it a shot.
Old 09-06-2003, 02:51 PM
rotary911porsche rotary911porsche is offline
Torque Central
http://www.torquecentral.com
has every answer you are looking for. Please use the search button before posting a question. They have two forums devoted to putting piston engines in any generation RX7. Any small block Ford or Chevy will fit. I believe a small block Mopar will also fit. Turbo buick V6s are another popular choice.
You definetely need an over drive tranny. 4.10 gears are hard on a V8 without over drive.
It is a very simple swap.
Porsche 911 with a Turbo 13B
Old 09-06-2003, 04:21 PM
MDiGiamm MDiGiamm is offline
Wouldn't almost any piston engine (especially a 5 liter V-8) throw the weight distribution off horribly???
Old 09-06-2003, 05:36 PM
No. It does not "throw the weight distribution off horribly".
Old 09-06-2003, 05:53 PM
with aluminum heads, relocation of the batter...and a few other things it is easy to keep the perfect 50/50 weight distribution.....
Old 09-06-2003, 11:16 PM
Hey would a turbocharged supra engine be any good. and would stuff like axles transmission, driveshaft etc have to changed according to the engine dropped in. Also am i just plain stupid to be looking at a Supra engine. What would be the best engine to drop in I woulud like to have it turbocharged. also what would a person have to relocate to get your 50/50 weight distrubition back
Thanks
Old 09-07-2003, 02:30 PM
Entreri33's Avatar
Entreri33 Entreri33 is offline
Send a message via ICQ to Entreri33
Why go to the expense and trouble of a supra engine???
Get a 3.8 series I out of a grand national or GNX you can make all the power of the supra and have the lower cost of an domestic engine.
There was that one supra7 in a magazine and they said it was a very hard install.
There are also kits to drop GM V8's into the car and the LS1 wieghs less than a straight 6 so the balance change would actually be less than the supra engine when finished.
But I doubt that the mazda rear end could handle the torque of any of those swaps so you would need to upgrade to a Vette or Supra unit and axles. Not to mention the Mazda tranny would have to go as well in favor of a LE60 auto or a T56 manual.
Had 2 cars totalled in 2 years.... searching for a new toy. Maybe another RX7(w/20b) or a 280Z(w/rb26dett)
I had...
87 RX7 sport (drove it for years)
01 Firebird
Need a new project car.
the 5th column will be the death of the american dream.
Old 09-07-2003, 09:20 PM
Ok
Everything sounds good that everybody has said about an engine swap.
But can anybody tell me the Best engine there would be to drop in to a RX-7 that would fit into the bay, and what transmission would go with the engine as well as fit into the body of the RX-7, and what would i have to install as far as axles, driveshafts, etc. what kind of axle and driveshaft would i have to install ( i mean a specific kind)
thanks
Old 09-08-2003, 04:47 AM
Entreri33's Avatar
if you've got a FD then just do the 20b swap
I had...
01 Firebird
