Old 09-04-2003, 07:35 PM
jdmcivic28 jdmcivic28 is offline
Question swaping in to my civic
If i was to swap a B16A2 engine in to my 97 civic what alxes, linkage, ecu, tranny, wiring and whatever stuff would i need.Would i need to get new alxes?If if i do need to get all that stuff for the swap.Where do i get it?
Old 09-04-2003, 11:16 PM
ravercivicdude ravercivicdude is offline
Re: swaping in to my civic
I have a 94 civic that I just put a b16a engine swap into and I needed 93 or above intagra axles to put on and a intermediate shaft if it doesn't have one.(mine didn't). I bought the shift extention rod from a 95 del sol that had a b16a3 engine in it. the dealer wants $98 for it.(ant to bad.) Just tell them you need it for a b16a3 1.6L Dohc engine. the shift rod is fine. you'll need the ecu that comes with the engine or a b16a2 engine and your car has OBDII and just make sure the engine does aswell. The axles are $60ea at Advanced Autoparts and the intermediate shaft can only be bought from dealer($300) or junk yard($60). If your civic doesn't have v-tec already you will have to run the silinoid, oil pressure, and knock sensor wires to the ecu. Also I had to by a MAP sensor also cause my car didn't have one. ($158) at www.autozone. should mount right up exactly. hope I answered your questions.
Old 09-06-2003, 02:21 AM
S13GTR S13GTR is offline
Maby you should find a place that sells the complete swap. You will save lots of money if you dont have to part everything and you will save time too.
Old 09-06-2003, 11:37 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea check out www.hmotorsonline.com the b16a i got came with everything i needed to swap into my crx minus the new mounts.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
How to take out a rear side window from a 96 honda civic Danthony_20 '96-'00 Civic 1 11-05-2009 11:38 PM
94 Civic with constant high pitch humming in front end.... lizshouse88 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-19-2009 06:49 PM
Civic Hybrid Cars-- '06+ Civic 0 05-04-2009 08:30 AM
96 Civic HX o2 Sensor Replacement.... shvd98z24 '96-'00 Civic 3 03-30-2009 09:49 PM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 12:43 PM
