Old 09-04-2003, 06:21 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
14b at 16 psi
first question. my cousin has a 14b that is in good shape and wants a 100-150 dollars, is that a fair price? if so could i run this turbo at 16 psi with an MBC on stock fuel infectors and no fuel management? because right now my car is pretty much stock except for a blitz BOV and a K&N(building home depot intake this weekend).
thanks for the help.
Old 09-04-2003, 11:50 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Look around your area and see how much used 14B's are going for, thats a good price in my area, but mabey not in yours.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 09-05-2003, 12:25 AM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
The 14B is a solid upgrade for the 2G. You'll need an adaptor for it though , I beleive , So it can bolt up to the exhaust mani , and the compressor outlet faces the wrong direction from what the T25 does. The T25 goes out underneath and toward the P-side fender , the 14B comes out on top and toward the radiator. And I'd say about $100 for a good 14B in excellent running condition is about average.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 09-05-2003, 12:45 AM
Talon007's Avatar
The 14B will bolt up to the Ex mani. The kit is for the water/oil lines
Chris Clark
www.Talon007.com
Old 09-05-2003, 12:49 AM
Re: 14b at 16 psi
Yeah , I was thinking about the T3's , don't ask me why. That requires a whole nother exhaust mani. But yeah , he's right , you'll need the kit for the relocated water and oil lines on the 14B. You can check RRE (RoadRaceEnginering) for those. And you'll need to reroute the plumbing coming off the turbo outlet.
Old 09-05-2003, 02:13 AM
my91gvr4 my91gvr4 is offline
Re: Re: 14b at 16 psi
The T3 does not require a new manifold. There are a number of kits (all really the same things) that will allow you to utilize the stock manifold. And the "2G install kit" works with the stock 2G IC pipe routing. The routing is not altered.
Old 09-05-2003, 02:37 AM
kjewer1 kjewer1 is offline
AF - Advisor
The "routing" is altered. A j-pipe is required to get back down to the LICP. All you need to toss a 14b on is the jpipe, and oil feed line. It can be had for less than 200 bucks, or you can pick up RREs hacker tweaker kit for 199 (fill kits are ~100 more, but you can reuse all of the metal gaskets). For the oil return line, simply file/drill/grind the two bolt holes clower together to match the spacing of the tdo5 cartridge. For water lines, simply swap the front with the rear, bend slightly as needed, and drive it on. Very simple, and it can all be done for 300 bucks. With this, BOV, exhaust, filter, AFC, boost controller, and race gas, I ran 12.7s. Others have gone faster. Defintely some VERY good bang for the buck.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-05-2003, 04:09 AM
Re: 14b at 16 psi
Thanks for the knowledgable reply. We need more of that around here.
Old 09-05-2003, 06:01 AM
AF - Advisor
Dont mention it. I dug up an old reply with a couple more details, but I think I covered all the good stuff above.. In other parts of that file I covered boost creep extensively. I forgot that I was getting creep to 22 psi, something you dont really have to worry about on the t25... If anyone is interested in that info, its a cut and paste away.
As far as the install I used RRE's "hacker/tweaker" instal kit for 200 bucks. Had everything I needed. The ONLY part that I would consider a pain in the ass was filing out the holes for the oil return line. But it beats removing it from the pan and having trouble with the infamous leaks. Now with my die grinder that job wouldn't take 5 minutes. Total job took me about 5-6 hours taking my time with food/drink breaks.
Also read the vfaq on 2G 16G install.... Tom Stangle put some notes in red about not switching the water lines front to back... I did this and it was a piece of cake. No extra water line necessary. Also, about all the hype about removing the stud... With the fan off (driver side) I have never had trouble removing the turbo or installing it in my 95, whether it was the T25 or 14B, so I always left it in. Everyone laughed and couldn't belive the stud was still there when they saw my 14b, but it works I did evetually remove it because in my quest to eliminate boost creep I was removing just the turbine housing itself about once a week And I got a handful of extra bolts from a NEDSM member at the local track hehe.
Kevin Jewer
Old 09-05-2003, 01:55 PM
Talon007's Avatar
Re: 14b at 16 psi
One mans garbage is another mans gold
Chris Clark
www.Talon007.com
Old 09-18-2003, 10:38 PM
95_GSX's Avatar
Alright here is what i got on my hands, a 14b with no shaft play for a hundred bucks, he said he would give me a stock 1G exhaust mani for free if i wanted it.(is it better than the stock 2G???) also could i build my "J" pipe out of 2-2 1/2" PVC and run it into my stock LICP??? i would need to switch the water lines front to back, and this is what i need some more clarification on "For the oil return line, simply file/drill/grind the two bolt holes clower together to match the spacing of the tdo5 cartridge." does Vfaq have more info, step by step instructions???? or any other help would be greatly appreciated.thanks
Old 09-18-2003, 11:43 PM
The 2G manifold is better. Keep yours and get the 1G to sell.
Old 09-20-2003, 02:01 AM
AF - Advisor
PVC and ABS is great, but only before the turbo. Some people use it after, but I defintely dont trust it with the after turbo heat. As for the drain line holes, the vfaq mentions it, but once you look at the parts it will make sense. Its very simple. The bolt holes are spaced farther apart on the 2g turbo/drain line than on the 1g turbo/drain line.
Kevin Jewer
Old 09-29-2003, 01:36 PM
95_GSX's Avatar
so who makes a good manual boost controler? and what brand of gauges are accurate and reliable? i dont want any bling bling non functioning POS.Thanks
Old 10-01-2003, 09:11 PM
95_GSX's Avatar
Re: 14b at 16 psi
needed to bring this back up, thanks.
Recommended psi verses Max psi. mchapman Tires and Wheels 27 02-26-2019 07:46 AM
Psi CAL2800 3000GT/Stealth 5 05-17-2010 10:31 AM
10 psi LS Vs. 8 psi Gsr motormike40 Forced Induction 1 01-05-2004 09:21 PM
T25 and 14B users OIL DRAIN INFO ....... dropshop '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-30-2002 06:44 PM
T25 vs. 14b fitting Rob80 Engine, Transmission and Drivetrain 1 07-28-2002 02:38 PM
