Old 09-04-2003, 03:23 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Big brake/rotor kit install help
My new engine (and my heavy foot) are wearing my budget DX font-only pads down to the bone prematurely, and I need sort of a step by step procedure in replacing my rear drums with aftermarket rotors. I assume they're pretty easy to replace up front, but any help there would be cool too. Would I need to buy new calipers to fit the larger brake pads? Within 2 months and 4k miles (I drive a lot ) I've worn new pads down to almost sparking metal on metal, and shined my rotors to almost mirrors. Also, which holds the better balance between stopping power/longetivity between slotted and drilled rotors? Thanks in advance.
Old 09-04-2003, 04:22 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
What kind of car is this we are talking about? A civic? sedan, 2dr or hatch? I know that you can take the whole rear setup off any integra and it will work on the 2dr and sedan but i am not sure about the hatch. And i have a et of cross drilled rotors and they have worked great for me. I have heard that the slotted ones hold up better to really hard braking so maybe those are what you want to look at. I dunno how they did it but I saw a pic of a civic that had porshe calipers and rotors on it, now that would solve your problem for sure
Old 09-04-2003, 04:56 PM
Ricochet's Avatar
Banned
Re: Big brake/rotor kit install help
All you gotta do is click on my name and it shows my car.
My rear drums are the same as any other Civic minus the Si which has all four as discs...
Old 09-04-2003, 07:22 PM
whtteg's Avatar
Re: Re: Big brake/rotor kit install help
Yea I thought about that after I posted the reply and then i got the server is too busy crap so I could not fix it LOL.
Anyway ya the rear control arms and everything else will swap over to your car, then you will have 4 wheel disk that should help some and then you could get some slotted rotors and carbon metalic pads thjat should help alot.
94 accord big brake upgrade kit theclassic32 Wheels/Tires/Suspension 6 01-27-2006 04:40 PM
Brake Rotor Question Please Help ASAP. G35turbo 3000GT/Stealth 3 12-23-2004 06:57 PM
How To change brake rotors and pads?????? HELP HELP MahdiVR-4 3000GT/Stealth 11 11-05-2004 03:11 AM
Need Help On What Glue I Need For Body Kit Installation....HELP PLZ!!! branman_crx_guy '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-13-2002 08:24 PM
big brake upgrade kit for sale 99+ golf or jetta 1.8t or vr6 4u2nv '97 - '03 1 07-08-2002 01:34 PM
