Old 09-04-2003, 02:35 PM
Cecil50 Cecil50 is offline
Angry What happened?
Just installed plugs in my 92 Taurus. It won't start after I did that and it was running great but needed plugs before I changed them. Put same kind in. Checked battery and grounds, checked to see if I knocked loose any wires, but it won't even click when I turn key. Didn't have a problem before. What happened? Sure a puzzling problem, but sounds like a ground wire or something to me.
Cecil
Old 09-04-2003, 04:20 PM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
Did you do them one at a time, to make sure the firing order stays correct? Did you remove the cap and rotor, or disturb the distributor in any way?
Old 09-04-2003, 04:55 PM
Re: What happened?
Took them out 1 by one, cap and rotor was not touched. Only pulled off each plug wire where it went on the plug. I have checked everything and so far have not been able to locate the problem.
Cecil
**Transmission Codes - What They Mean and What Happens** blazee Blazer 2 06-30-2005 08:16 AM
**Transmission Codes - What They Mean and What Happens** blazee Sonoma | S-15 0 06-29-2005 05:15 PM
**Transmission Codes - What They Mean and What Happens** blazee Jimmy 0 06-29-2005 05:11 PM
**Transmission Codes - What They Mean and What Happens** blazee S-10 0 06-29-2005 05:04 PM
whats going on here? what happened? brads94accord Accord/TSX/Accord Hybrid 5 12-07-2001 10:58 PM
