Old 09-04-2003, 03:22 PM
philly honda philly honda is offline
engine swap
I have a '89 civic si which is quite quick,but would it be possible to fit a b20a motor?
Old 09-04-2003, 03:42 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
ya, you can fit any b-series engine into your car as long as you buy the mounts and everything else you will need to fit it right into the car
KoRnSaQ
Old 09-04-2003, 06:22 PM
91zc 91zc is offline
If you are talking about the b20 out of the late 80's earl 90's prelude then it won't work unless you make your own mounts. But even then it isn't worth it since there are so many other motors out there that will bolt in with a mount kit. If you are talking about the b20b/z from the crv then it will fit with minimal work.
91 civic 4dr
b16a
14.8@94
dakota engine swap jpuckett13 Dakota 0 08-23-2010 08:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 10:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 10:33 AM
engine swapping E. Frank Performance 6 08-07-2009 07:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 10:40 PM
