Go Back   Automotive Forums Car Chat > Honda > Integra
Old 09-04-2003, 12:58 PM
91Intergra 91Intergra is offline
Send a message via ICQ to 91Intergra
Exclamation Car wobbling when gas is applied? Problem help
So these are the symptoms. When i put my car in 1st and start to roll away, it has a very light light wobble. As if the car moves from left to right rocking, kind if a wheel was bent or out of line. Now when you gradually pick up sweet there is very little wobble, a half decent smooth ride, but if you put the pedle to the metal she wobbles like a fat kid with his pants down. Shakes me entire car like theres no tomorrow.
SO i jacked my car up both from tires off the ground, gave both tires the full ball bearing and tire rod test. The left side was tight and perfect no play, the right side failed the tyre rod test, it had play from side to side. I put my left hand on the outside of the tire and my right hand on the other side outside of the tire and gave it a good shakin. So i found out that the tire rod was shot, so i replaced it.
Still wobbling.... Then i went to burger king today for lunch and was talking to my buddy about my car and this guy behind me over heard and said that it was prolly my steering rack or low power steering fluid. Or my motor mounts were shot, so i popped the hood and tried to move my engine, nothing, all joints are clean and no wear.
So while my car was jacked up, i turned on the car and put it in first gear.. Only my drivers side tire was spinning? Gave it gas, and still my drivers side tire would only spin... So i put my hand and tried to stop my drivers side tire, finally slowed it down and the passenger side kicked in and started spinning. They both looked as though they weren't wobbling or anything, they were both balanced yesterday as well.
So my only conclusion could be? CV joint? Or steering rack? Maybe tranny since the wobble only occured once that clutch has been engaged and gas has been applied.. Really dont know
anyone?
Tim
