Originally Posted by rsholtis2003
Everytime I turn the key to turn it over it makes a loud buzzing noise. At first I thought it was the battery so I replaced it. It worked for about a day or so and then it did it again. So I listened to where it was comming from and it is right on the cylanoid. So I replaced that and it still does it. I then thought it could be the starter. So I had it tested and it was fine. So I thought it could be the wiring but I really hope it isnt, that could take forever. Maybe something isnt hooked up right? Not enough ground ire? Maybe its something else? If anyone has any thoughts or ideas I could use them. Thanks
Check all the wires at the starter,the battery and silnoid for bad connection. Green or wight corrosion. Check ground wires at the engine and battery.
