Inspection Results: Failed
Well i knew it was going to fail. I only did it to see what i needed to get fixed but here we go. im going to give you the list.
Parts that need replacement: Left innertieRod Rear Wheel Cylinders Rear brake drums Front Rotors (current are drilled and are illegal in the state of MD) Catalitic Converter Muffler Side Markers Fuel lines to gas tank (Rusted) Floor panels Needs Adjustments: Battery loose Battery Corrosion Headlight adjusters Alignment ...Project 3GSi has now been started
~1987 Honda Civic Si~ |
Dude junk it
and get a new better 2nd gen crx that has safty and all that shit done its ganna cost way to much man $$$$$$$$$$$$$$$
Well first off, it sounds like Maryland sucks ass for inspections.
Don't give it up just yet though buddy. Anywho: Left innertieRod Easy and cheap Rear Wheel Cylinders Rear brake drums For this and the above, just swap over some 1G Integra rear disc brakes, drums are for muscle cars. ![]() Front Rotors (current are drilled and are illegal in the state of MD) Just get some OEM replacement solid-vented Brembo rotors. Or you can upgrade to Integra front brakes too, or 4G Si brakes. Catalitic Converter Muffler Custom exhaust time! Side Markers Salvage Yard Fuel lines to gas tank (Rusted) A bitch and a half to replace. Floor panels Ditto, unless you are a welder. Needs Adjustments: Battery loose Battery Corrosion Headlight adjusters Alignment |
