Old 09-03-2003, 09:45 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
custom exhaust?
should i just build my own custom exhaust, cause wyoming doesnt have emissions. and if so how should i do it? solid 3" all the way out? or 3" into an apex-i N1 muffler. your thoughts and info would be apprecieted.
Old 09-03-2003, 10:20 PM
kjewer1 kjewer1 is offline
AF - Advisor
Building your own exhaust is badass. I Saved a ton of cash, and its done the way I want. I dont care about stainless either, so I was able to weld it all myself. Check out the thread on www.racingknowledge.org for the details. I wrote a pretty thorough expalnation of what I did, with tons of pics. You may have to search to find it, its from last november. If the pics no longer work, I'll try to get a VFAQ of some sort up on www.posracing.net.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-03-2003, 10:44 PM
95_GSX's Avatar
hey thanks for the links, i will go and search them out. thanks 95_GSXracer. bye the way i really like tho posracing website u have.
Old 09-04-2003, 01:02 AM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
My ESi should be on there, its a bonafid POS, but I drive 'er on
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 09-04-2003, 04:07 PM
AF - Advisor
lol thats what its all about. Our cars could be broken down with parts falling off it, but we still drive them to work everyday and take it to the track
Kevin Jewer
Old 09-04-2003, 05:23 PM
95_GSX's Avatar
hey kevin i found the posts that talked about all the work u had gotten done on your car but i never found the thread on your custom exhaust. so if you could link me to that, or build that vfaq on posracing, it would be appreciated. i am going try and get my exhaust done here soon. thanks.
P.S. kevin: did you build your own down pipe???
Old 09-05-2003, 02:04 PM
95_GSX's Avatar
hey i just needed to bring this back to the top so i could get some more questions answered. thanks
Old 09-18-2003, 11:54 PM
95_GSX's Avatar
Re: custom exhaust?
hey guys just wanted to bring this back again. replies welcome.
Old 09-20-2003, 03:05 AM
AF - Advisor
I will try to get back to this. But I dfintely dont have much time on my hands. I dyno all day sat, then leave for oregon for two weeks. Not sure if I'll have internet access out there.
NEvermind, its your lucky day HEre is the thread, and all the pics still work on quick inpection. Badass. Enjoy.
http://www.racingknowledge.org/topic...xhaust,dynomax
Kevin Jewer
Old 09-29-2003, 02:46 PM
95_GSX's Avatar
Alright after some deliberation here is my plan, RRE short DP, build my own TP, aluminized 3" steel exhaust, dynomax 3" I/O ultraflow welded muffler and some mandrel bent 45's.
Old 09-29-2003, 07:10 PM
95_GSX's Avatar
oh yea to cut down on heat radiating on to my engine i am going to wrap my DP? has anyone else done this?? comments?? thanks.
Old 09-30-2003, 06:03 PM
DeJa_Voo DeJa_Voo is offline
I was also thinking about a custom exhaust but what does the fabrication shop need to know about the exhaust system? I have a 99 GST and would like something like a thermal R&D or apexi n1 setup but how should i tell them that or would they even know?
Old 10-02-2003, 12:15 AM
95_GSX's Avatar
i would build one similar to mine, except use an n1 muffler if you want, oh and use the FWD RRE DP. short or long what ever you prefer. good luck.
Old 10-08-2003, 10:27 PM
95_GSX's Avatar
Re: custom exhaust?
replies welcome. and will putting on my exhaust effect the pressure my turbo boosts at? will i need to a MBC with my custom exhaust?
Old 10-10-2003, 12:16 AM
AF - Advisor
Wrapping the exhaust has advantages, but it causes some premature corosion. In fact, header companies typically wont hnor a warranty if it was wrapped for that reason.
Your set boost wont be affected, but creep, or the tendency to do so, will go up. Especially if you dont use a cat. for example, on my car with the 14b. With a BR 2.5" turbo back with high flow cat would creep to 18 psi. With a test pipe, it went up to 22 So be prepared to take some counter measures (porting).
Kevin Jewer
