Old 09-03-2003, 06:25 PM
Redrunner Redrunner is offline
Send a message via AIM to Redrunner
check Engine light
My check engine light is one I just installed my CIA and the light came on I hook the o2 back up and everything. The guy at auto zone said there is nothin I can do about it is. this true
1999 Honda Civic DX 1.6l I4 (Stock)
Track Best : 17.010 at 80.822 0.070 r/t (THIS IS WITHOUT N2O THIS IS MY STOCK TIME)
MODs:
Real Cold Air Intake (the one that sucks air from under car)
Compucar NOS hybrid wet fogger system (55 shot)
Old 09-03-2003, 07:14 PM
esp's Avatar
esp esp is offline
Send a message via AIM to esp Send a message via MSN to esp Send a message via Yahoo to esp
well where u careful when u took the sensor out, cause u might have broken it, this is the first case i have heard of having the CE light come on after a CAI install. try disconnecting the battery terminal and reconnecting it.
*RIP* Integr8 aka Ryan *RIP*
5/29/03
www.fotki.com/esp
THIS OG IS GONE retired for good. peace yall. create a crew for me
Old 09-03-2003, 07:46 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
As esp already stated. All you have to do is reset the ECU. The sensor on my girls just got unplugged. I plugged that b*tch back in, reset the ECU and no more CEL. OBDII SUCKS!!!!
Old 09-03-2003, 07:54 PM
Re: check Engine light
now in my other car reset ECU was easy I just pulled fuse
How do I do it in my car
MODs:
Old 09-03-2003, 08:01 PM
B16EJ1's Avatar
You can do either. Pull the fuse or unhook the negative on the battery for a while.
Old 09-03-2003, 08:06 PM
esp's Avatar
esp esp is offline
u car is probably like mine cause it is a 6th gen, we dont have a fuse for the ecu that i could find, just unhook the battery for like 10 min or so then re hook it up and start the car up and u should be fine.
5/29/03
www.fotki.com/esp
Old 09-03-2003, 08:13 PM
B16EJ1's Avatar
I was reffering to a 6th gen. My girl has a 99 hatch. I never did the fuse thing but I thought there was one in the 6th. Anyway. I've never had to even reset my ECU.......Like I said OBDII SUCKS
Old 09-03-2003, 08:22 PM
ok I un hooked battery do I do + and - or one or the other
MODs:
Old 09-03-2003, 08:44 PM
Re: Re: check Engine light
NM it worked Ty guys damn I love this Forum (sometimes now) now that I got intake ready to start running 12s
MODs:
Old 09-03-2003, 08:47 PM
esp's Avatar
esp esp is offline
Re: Re: Re: check Engine light
actually u will get some better performance from resetting it because it will sense a change and then the ecu will think that, and i am positive now that the 6th gen does not have a fuse for the ecu.
5/29/03
www.fotki.com/esp
Old 09-03-2003, 09:01 PM
Re: Re: Re: Re: check Engine light
I hope so should I get ECU reprogrammed before add my high flow cat my headers and exhuast or go to a ODB1
MODs:
Old 09-04-2003, 12:11 AM
B16EJ1's Avatar
For simple mods like those a reprogrammed ECU is not at all necessary. OBDI conversion is also not really necessary but I'll tell you that I am damn greatful for my OBDI.
Old 09-04-2003, 12:13 AM
will I am about to go with a custom turbo or Zex. I am think ZEx cuz my mom drives car sometime and if it is fast then she is going to be on the gas all the time and get alot of tickets. Mom (has lead foot Know I know where I get it from)
but would I need OBD1 for this or you dont think it is need
MODs:
Old 09-04-2003, 08:06 AM
esp's Avatar
esp esp is offline
all i have to say is huh???
5/29/03
www.fotki.com/esp
Old 09-04-2003, 05:29 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
The 6th gen ECU fuse is under the hood called.
F/I EM (engine management)
The only reason the check engine light would come on from an intake is if you broke the sensor, unhooked it or did not plug it into the intake.
M.Sanew - AutomotiveArticles.com
