Old 09-02-2003, 05:52 PM
blade34609's Avatar
blade34609 blade34609 is offline
MPFI making me go Crazy!
Hi,
As you guys know I finished my MPFI swap.
Well, the car start right up perfectly and idles good.
But the car still wont rev past 3000 RPM!
With the car turned off but the ignition on I get these codes:
6: Coolant Temp
10: Intake Air Temp
13: Atmospheric Pressure
Today I just put a new Intake Air Temp sensor in cause my old one the plastic was broke off. I thought that by doing that it would make code 10 go away and possibly 13. But it didnt.
I also tried shielded wires from the C1 ECU to dizzy.
That didnt work either.
I double checked my wiring and checked to make sure nothing was loose and all the wires are soldered correctly in the right places.
I really dont know what to do. I gotta get this car running.
Its almost impossible to not be able to rev past 3000 while driving.
So if any of you guys could help me it out it would be greatly appreciated.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 09-02-2003, 07:07 PM
gsf1200m gsf1200m is offline
Did you also shield C2, and did you try other wires than those rcas?
I dont know if rcas are shieled or anything, but the shielded wires i got worked.
Old 09-03-2003, 05:44 AM
redmanjd redmanjd is offline
try swaping the wires for the intake temp and the coolant. there are three or four plugs on the engine that are exactly the same.
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 09-03-2003, 02:34 PM
blade34609's Avatar
Re: MPFI making me go Crazy!
Ok ill try.
But where exactly are the plugs?
And all I changed was the intake manifold and ECU.
What would be the number one cause for the 3000 RPM rev limit?
Im about ready to take the car to a professional, lol.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Crazy Acccident fjmustak Car Videos 2 11-23-2010 02:02 PM
Help with make/model identification saltyone General Discussion 1 04-27-2010 08:51 AM
CVPI making crazy noise glen107wood Crown Victoria 2 01-19-2007 10:39 PM
'91 3.0L 6 Cyl. making crazy noise... raebear26 Ranger | Courier 1 01-03-2005 03:59 PM
Have tehy gone RICE crazy? Why do companies make this crap? kane2g Forced Induction 3 04-12-2002 10:40 PM
