Old 09-02-2003, 02:55 PM
delaSOUL delaSOUL is offline
b16a2 and V-AFC
I drive a 96 del sol with the B16A2. When I bought the car it had a few extras. A DC Sports 4 to 1 header, AEM ram air intake, and a Apex V-tech Air Flow Converter. 2 weeks ago, the V-AFC was stolen. The car now idles higher than normal, lags in power, and is sloooooooooow! I did turn the distributor cap up 2 nothces which helped with the lag a little. I need to know what I should do to return my car back to good running order. Thanks for any advice.
Old 09-02-2003, 02:58 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
could always buy another Apex V-tech Air Flow Converter.....dejavu(sp)
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-02-2003, 03:24 PM
So far my insurance company wont cover it, being an "aftermarket accessory" and I dont have the money to cover the cost of a new one. I just want thing back to normal.
Old 09-02-2003, 05:49 PM
94civic's Avatar
94civic 94civic is offline
you should try removing the harnes for the vafc and connect any wires that are cut. i know that when you install the vafc you have to cut the vtec solenoid wirre in half so that the vafc could intercept the vtec signal. is the vtec working? if not then connect the wire back together and it should work.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 09-02-2003, 05:50 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Re: b16a2 and V-AFC
Dude thats easy. Assuming they werent nice enough to rewire the ecu back to stock when they were done stealing, then you need to. The vafc intercepts the VTEC, VTM, and MAP signal from the engine, modiefies it, and then sends to the ecu. Pull your ECU out and look at where you stock harness was cut and spliced. Join the stock wires back together and you should be in good shape. If you arent goint to replace it, the might as well pull all the other wires out too that were just tapped off factory wires.
Old 09-02-2003, 05:51 PM
Re: b16a2 and V-AFC
AWW you beat my while I was typing...
Old 09-02-2003, 07:31 PM
thanks fellas, i'll get on reconnecting the ecu
i did have a buddy turn up the timing, should i turn it back down?
Tuned.com's Fast and Furious Release Party and Car Show April 3rd and 4th HotCtyPlaya North East 2 03-28-2009 03:32 PM
turboing a b16a2 and have sum ???? elaxxx N2O | Turbo | Superchargers 5 04-17-2005 01:29 PM
b16a2 and b18c1 KaMaKaZiPyRo Let's get Technical! 1 06-17-2004 12:39 AM
Reglage Apexi V-AFC on B16A2 Ludo Engineering/ Technical 0 05-29-2003 07:41 PM
