Old 09-02-2003, 10:10 AM
HondaDriver82 HondaDriver82 is offline
b16 swap into 6g
Hey, I was doing research on the b16a2 Sir swap into a 6g civic, I now what axles, shift linkage, and ecu i need, so the only thing i want to now is what wiring is involved, because every where i look all it says is "wiring modificatios involved". And thats not helping me at all, Wirig wise i now that i have to change the injector connectors on my 98 lx harnss, and i'm pretty sure i have to chang the connector on the distributor, becasue me and my friend just finished doing a b16a1 into a crx si, and a b16A2 Sir into a 92 hatch, with both bottom ends built but anyway i saw on the b16a2 Sir engine that the distributor connector is different on mine, so thats no problem, vtec , oil pressure, and knock is no problem either, i just wnat to now What else needs to be modified on my wiring harness? Any one that did this kind of a swap into their 6g civc , please give me some info on what you did on your swap!!!
