Old 09-02-2003, 08:39 AM
oldsisreal oldsisreal is offline
88 f150 egr
I have an 88 f150 5.0 auto with air and I am getting no egr vaccume at the valve. I removead and cleaned and tested valve which is ok I back traced vac to egr vac solonoid good vac from manifold but no signal from ecm. I changed out vac solonoid with a known good one but no help. Is this a faulty ecm ? Ideas ?
Old 11-06-2003, 12:32 PM
DanTana DanTana is offline
Re: 88 f150 egr
You might want to check the MAP sensor located on the firewall and maybe pull the codes off your computer and see what it says.
Old 12-09-2003, 09:17 AM
Thanks a million ! Map sensor did it. eng runs 100 %
