Old 09-01-2003, 01:29 PM
ksolomon ksolomon is offline
engine surges when car is idling
When the car is idling the engine surges. The motor speeds up then slows down.
Old 09-02-2003, 08:09 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
What year of Taurus is it? Up to '96 they had EEC-IV, '96 on was EEC-V.
The earlier computer is easy to check without the handheld display. You'll need a SuperStar, or similar unit (Actron is good) to check a '96-up car with OBD-II.
The first thing to do on a computer-controlled car is see if there's any codes stored by the Electronic Engine Control. This will get you started off in the right direction.
Also, www.tauruscarclub.com is good for troubleshooting problems. So many things can cause this idle problem that I don't want to guess and send you on a wild goose chase.
Old 09-04-2003, 10:26 PM
Jays_sho's Avatar
Jays_sho Jays_sho is offline
Had the same problem it turn out to be the IAC connector at the throttle body. My car was surging and I popped the hood and moved the connector around and it stopped, Just needed cleaning. And I think Ford did say somthing about a problem with the connector too...
http://www.superford.org/registry/ve...x.php?vID=2205
*Vibrant White 1997 S-H-O
*Arctic White 1993 Corvette
*Red/Silver 1987 Firebird Pro Am II
*Burgandy 1978 SAAB 99 Turbo
Old 09-18-2003, 11:38 AM
It was a '93 Taurus. The owner of the car decided to trade it in for a newer car, without having the problem analyzed. Thanks for your help, though.
Old 09-30-2003, 11:14 PM
stevep stevep is offline
Re: engine surges when car is idling
[quote=ksolomon]It was a '93 Taurus. The owner of the car decided to trade it in for a newer car,
I think this was my car... If it was a green taurus wagon with approximatly 145,000 miles.
If so I replaced the IAC.
Old 10-03-2003, 07:35 PM
mikeo550 mikeo550 is offline
hm
if the IAC dont work try cleaning your fule injectors... sometimes when they dont spray right its like flooding your engine and it will rev up to burn that fule away
95 DX engine surges when in idle vbcamry '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 07-04-2006 11:53 AM
Engine surges when maintaining speed. heyrobb MY 01-06 8 01-08-2005 07:14 PM
93 grand prix Engine surges when accelarating and Idles high then drops to normal. stra8uphoosier Grand Prix 0 07-12-2004 12:33 AM
91 lesabre engine surges when stopped rocksaround LeSabre 0 01-28-2004 09:57 PM
