Old 08-31-2003, 04:05 PM
Mouaracing Mouaracing is offline
HELP! Clutch Pedal won't come back up.
I've searched and nothing came up. I have a 93 prelude S (F22A1) and my clutch pedal goes to the floor with now pressure and stays there and i have to pull it out. There is no pressure so I can't even shift into gear while the engine is running. I have changed the master and slave cylinders and the problem has not been fixed. I have also put compressed air into the line to check for leaks and there are no leaks. I see no trace of hydraulic fliud leak either. I need my car to get to work and I need help asap. Can anyone one help me out, Could the problem be the clutch?
Old 09-01-2003, 07:40 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
you have air in the line. bleed the system properly.
Old 09-01-2003, 03:13 PM
gwabber72 gwabber72 is offline
Re: HELP! Clutch Pedal won't come back up.
I work for a dealer I see this alot. You need two people to do it. Go to slave cylinder open valve. Put your finger over valve lightly while your budy pumps the whole time. You want fluid to come out under presure. Also while valve is open push end of slave cylinder back twards valve. Once it starts to flow close valve, have budy pump up and hold. Open valve.good luck!
Old 09-02-2003, 04:27 AM
drift's Avatar
Re: Re: HELP! Clutch Pedal won't come back up.
it can be done even easier with just one person by manipulating only the slave cylinder.
