Old 08-31-2003, 03:48 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
b16 swap/ throwing code 14
I just completed my b16 swap into my 91 crx, and the ecu is throwing a code 14 and 21. Code 21 i believe is because i havent hooked up vtec yet but code 14 is the (idle control valve) and the only problem with the engine is that it wont idle, it idles like really rough and stalls out within 10 seconds, I have no idea what the idle control valve is, any help on this would be appreciated
Old 08-31-2003, 09:02 PM
cmon no one knows what a code 14 is or what a idle control valve is? If no one knows then were can i find out? please help
Old 09-03-2003, 05:50 AM
redmanjd redmanjd is offline
the idle air control valve is the metal valve attached to the back of your intake manifold. It controls the air that flows around the butterfly(throttle body) to let it idle when it is closed. I had to replace mine because sitting in a junk yard for 8 months with no water they tend to freze up.
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
