Old 08-31-2003, 02:35 PM
gsf1200m gsf1200m is offline
Finally finished mpfi swap!!!!
Well i swapped it into my '91 STD.
It wasnt too hard to do, all the wiring and hoses and stuff was pretty straight forward.
There is definetly more power, but not as much as I was expecting.
I think my problem now might be my 4 speed, i gotta swap it out sometime.
First gear pulls way harder, then 2nd drops off a little bit, then third, but I guess that is what it did stock anyway.
Mpfi sure looks a lot better and sounds a lot better than stock.
So future mods to go faster are:
5 speed
Si cam
header, high flow cat, 2.5 inch piping or somewhere around there.
I already have an intake so all that other stuff should make the civic pretty peppy.
I'm going to the track probably wednesday, I got 18.4 stock, and I was hoping to get into the 16s, but I'm not sure anymore.
The only problem I have now is that the speedometer isnt working, anybody know what this could be from?
Old 08-31-2003, 03:09 PM
Now i have a code 9 which is no. 1 cylinder position sensor.
It wasnt there when i drove the car last time and i havent done anyting.
It runs fine and seems the same as before.
Maybe its just a loose wire or something.
Old 08-31-2003, 04:28 PM
WindyIce's Avatar
WindyIce WindyIce is offline
Send a message via ICQ to WindyIce Send a message via AIM to WindyIce
hmmmm
So what process did you take to complete it I'm just curious. I might do it for the hell of it before I get my B16A.
**!!4thgen in the projects!!**
B16A LSD JDM With Entire Car
Old 08-31-2003, 04:34 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
#9 is the cylinder position sensor, its inside your distributor, supposing you made sure to put on an Si distributor. If you didn't than that is why you are throwing a code.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-31-2003, 04:48 PM
What do you mean what process? Im happy to answer any questions about it since it is fresh in my mind. I want to do a swap someday, but until then this was a good way to learn a couple things about my car.
I got my code 9 to go away.
I just checked the wires and they must have been to close or soemthign.
THere was no metal to metal contact, but when I moved them it went away.
My speedometer hasnt worked since i did this, and after like 20 minutes the vehicle speed sensor, code 17 came on, which makes sense.
I guess i will search around and see what that is about.
Old 08-31-2003, 05:23 PM
Well i think my speedometer problem is that somewhere along the way during the swap i unplugged it by accident, at least i hope so because that woudl explain why it doesnt work.
THere is a raised edge on the cable so does it only fit in one way?
And how do i find that one way because ive put it in many ways and it hasnt started to work.
Old 08-31-2003, 07:52 PM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
91 std civic.....d15. might i suggest a zc/si hybrid tranny. thats what im running in mine. really close 2-5 gearing. highway rpm 3750@75mph. consistes of si tranny mainshaft and counter shaft with zc 3-5 gears. and the si final drive. knocked off a whole 3 tenths off my 1/4 time.
Old 08-31-2003, 11:14 PM
Thanks for the suggestion.
I will probably start looking at trannys next spring, right now I'm in school so I cant get much done.
I got the speedometer cable back in and it worked, everything is working fine, mpfi was a success.
Old 08-31-2003, 11:22 PM
blade34609's Avatar
blade34609 blade34609 is offline
Re: Finally finished mpfi swap!!!!
You are soo lucky your MPFi swap was a success.
I still havent got it running right.
Read my most current post and you will see why.
http://www.automotiveforums.com/vbulletin/t132382.html
If its not too much of a bother could you or anyone else look at your MPFi intake manifold and tell me if you have a Fast Idle control Solenoid Valve,its on the back of the manifold.
I think thats the reason my car limits the rev at 3000 and has slow throttle response. My intake manifold doesnt have this.
Here is a pic of the SI Manifold Diagram:
http://www.binghamtonlife.com/manual...s/91-11-17.jpg
You will see a pic of what it looks like.
Thanks Alot.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 09-01-2003, 07:12 AM
Ya i was reading your post.
I do have that on the back of my manifold, it looks just like the thing in the picture.
Are you getting a vacuum leak because it is not there or is it just idling high?
Actually, have you let your car warm up all the way and seen if the idle has fallen down?
When it is cold it idles up around 2 like yours, then falls back down to normal.
It takes more time to do so than before teh swap.
I think it might be because my fast idle thing isnt hooked up, I dont know if it is supposed to be but if it is I'm just not seeing the wires that go to it.
I think I read somewhere that this has something to do with the idle when the car is cold, ill search a little bit.
Old 09-01-2003, 07:14 AM
Ok, i just read your post somemore.
The vacuum leak is what is making it idle high.
I had that same problem, my IAT was missing and I didnt even realize it.
If you plug those holes up with something or get the thing that goes there you should be all set.
Do you still have the 3,000 redline?
I had this, and it is because you need to use sheiled wires from C1 and C2 to the distributor.
I also had this problem and as soon as i put shielded wires in it went away.
Old 09-01-2003, 09:15 AM
blade34609's Avatar
Hi,
Ok thanks for the help.
what exactly to you mean by sheilded wires?
Yea I still have the 3000 RPM redline.
Right now I have a piece of metal with 2 10mm bolts holding it in place. But if you look at the diagram it shows that the Fast idle Solenoid has a hose that goes to it?
Yea when I put that piece of metal over it dropped from a 2000 RPM idle to a 900-1000 RPM idle.
I had to have wired it correctly though, right?
beacuse it wouldnt run if it was wired incorrectly.
I probably just need those shielded wires to the dizzy?
Do you think this is also causing my slow throttle response?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 09-01-2003, 11:37 AM
If you plug up the holes you should be alright to drive it around.
I dont have mine hooked up right now.
Did you have wires to hook it up with and where are they?
I think mine must have fallen where I cant see them because they must be there.
I think that is what is giving me a high idle right now.
I got the shielded wires from radio shack, i dont know why they help but i read online that they did and it worked.
I got two wires for $3.99 that had a headphone jack on one end, and aligator clips on the other.
I just cut the two ends off, and wired it to the distributor.
What do you have an STD or a dx and any mods?
Also, have you been to the track before and are you gonna go after the swap?
Old 09-01-2003, 11:45 AM
blade34609's Avatar
No I dont have any wires to it. I guess the guy i got the manifold from musta took the idle solenoid.
I have some RCA cables from my last AMP installation.
Could I just take the RCA cable and pull it apart then solder it from Dizzy to C1 and C2?
I have a 90 Civic LX.
My mods are a short ram intake and Gt Spec muffler.
I plan on doing a little bit more latter.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 09-01-2003, 01:21 PM
I dont know if rca cables would work but its worth a shot.
So do you know where the idle solenoid hooks up too?
You planning on going to the track after the swap?
