Old 08-31-2003, 01:47 PM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
Whats it take to run low 13's?
Whats it take to keep up with a very lightly bolt on'ed LS1 from a roll????
Edit: Oops.. forgot to mention that I'm basing this question off stock 5.0's with manual trans.
when in doubt, throttle.
Old 09-01-2003, 09:03 PM
CB91StangGT CB91StangGT is offline
Send a message via AIM to CB91StangGT
A good h/i/c combo, very low (atleast 3.73's) set of gears out back, full exhaust, all the bolt-ons, et streets, one hell of a good driver, and last but not least a lot of luck (to walk an LS1 that is).
1991 Mustang GT Conv: 60,000 original miles, 2nd owner :banana:
Built AOD w/2800rpm stall, 3.73's, aluminum d/s, 2 chamber Flowmasters, BBK shorties, 65mm tb, 73mm maf, subframe connectors.
1990 Mustang LX Conv 25th Anniv: 50,000 original miles, 2nd owner :banana:
2 chamber Flowmasters, o/r h-pipe, Pro 5.0 shifter.
Old 09-02-2003, 03:13 AM
Los Los is offline
Send a message via AIM to Los Send a message via MSN to Los
Cheap:
Comp cam matched with Edlebrock Performer intake and AFR 185 heads with 3.73s and a short throw.
Los
Texas Racing Scene.com
Lawton Racing
Old 09-02-2003, 07:47 AM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Low 13's in a mustang is pretty easy with just exhaust, a 3.73 gear and bolt-ons.
Old 09-02-2003, 08:46 PM
Re: Whats it take to run low 13's?
Originally Posted by Los
Cheap:
Cheap???? How cheap is that combo?? Man.. I need a grip of stuff...
We're talking about 5.0 Foxbodies here....
Old 09-02-2003, 11:01 PM
boosted331 boosted331 is offline
You want a pretty cheap way to outrun LS1's? JYTT baby. ALl it takes is a set of 200 dollar shorties, flip em upside down, cut the header flanges off with a chop saw, weld on a T3 flange, throw 2 junk yard T3's on there, rig up some piping and go to an intercooler if you want (powerstroke with new end tanks and cut down works nice) and get a good tune or swap to a carb and you'll run those LS1's down Can be done for a bit over a grand if you know how to barter.
Old 09-02-2003, 11:45 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
JYTT good stuff but you gotta know what your doing with turbos not everyone does not saying anyone doesn't though. Id say I/H/E gears 3.73s and a cam should do it good light wheels and tires never hurt either.
Old 09-03-2003, 01:47 AM
Los Los is offline
Re: Re: Whats it take to run low 13's?
Look to about a grand for the heads, maybe five hundred for the intake and two hundred and fifty for the cam. Or you can just do a mild port job on the E7TEs or whatever set of heads you got and spray the mofo.
Los
Lawton Racing
Old 09-06-2003, 08:51 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
i have a 89 GT do i have the E7TE's
How do you identify the type of heads you have?
are they the best ones for stock?
and what do you mean by spraying like a coating inside the ports?
Old 09-07-2003, 09:01 AM
Los Los is offline
If you have a 5.0, yes.
Pull off the head. There should be a casting number.
Compared to the 82 heads and 85 heads, yeah. But marginally.
When anyone uses the term 'spray' and liberally at that, he or she probably means using the 'nitro' (lol) and juicing your car with like a 100 shot or something.
Los
Lawton Racing
