Old 08-31-2003, 10:08 AM
D.J.'s Avatar
D.J. D.J. is offline
Help a newbie - priming
First: yes ive read the faq, but i still have problems. Ive sprayed a couple of layers but i can already see it will be (is) orange peely If i spray at a great distance it makes peel and if i go closer too much primer gets on. Now its drying, here´s a pic. What should i do?
http://freeweb.siol.net/vmurko/bad.JPG
Old 08-31-2003, 10:23 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
You just have to get some practice and have it at the right distance. You should strip it down and redo it.
Old 08-31-2003, 10:38 AM
D.J.'s Avatar
Damn, easy to say, very hard to do (re-do that is).
Old 08-31-2003, 11:46 AM
egon_dude egon_dude is offline
Send a message via MSN to egon_dude
keep on spraying a few more light coats, as long as you cant see the base plastic you should be ok. then get some fine (about 1200-1500 grit) wet and dry paper- the dark grey stuff, and sand out all of the orange peel using plenty of water. Dont worry if you rub though to the plastic, just touch it up with the spray and carefully rub it down again. Its usually worth waiting a week for the primer to harden up before you sand it, as then theres less chance of rubbing through it. Dont worry- most primers go a bit orange peely. Well mine do anyway, but you can still get excellent finishes.
Good luck, matt.
Only smarties have the answer . . . .
Old 08-31-2003, 12:06 PM
D.J.'s Avatar
OK, thanx ill try that. Ive done second time and its a little better - except i rubbed parts of plastic that i shouldnt
Now ill wait a week and then sand away the orange peel.
Old 08-31-2003, 03:12 PM
Tea Tea is offline
Ya wet sanding is an option
in future to prevent this, may I suggest you to spray closer, but faster
so less primer gets on but the distance is close enough not to have orange peels
at least thats how I do it =)
Old 08-31-2003, 04:06 PM
D.J.'s Avatar
Any tips for how to paint? Same as primer?
Old 08-31-2003, 04:36 PM
Tea Tea is offline
warm and shake can well beforehand.
give it a hard spray on somewhere unimportant after shaking
never start or stop on the body
start elsewhere and move the can to the body, and stop elsewhere
spray close and fast, in mulitple mist coats, each coat being 10 mins or so apart
last few coats being wet ones.
store somewhere dust-free and allow to dry
after it dries, rub it with 2000 grit to get rid of orange peel and unevenness (that a word ?)
wash and allow to dry
shoot 1 or 2 wet coats
by now the car should be ok
then clearcoating, polishing and waxing is another story.
just my
Old 08-31-2003, 04:38 PM
D.J.'s Avatar
OK, whats a wet coat?
Thanx 100 times
Old 09-01-2003, 04:34 AM
primera man's Avatar
"P-Man"
Re: Help a newbie - priming
Thanx 100 times
Do mist coats first which are sprayed at a distance. The wet coat is painted closer and slower so you get a heavy coat on
View All My Models Here.
Old 09-01-2003, 10:27 AM
D.J.'s Avatar
One more (stupid) question: must i prime all the parts or can i paint the interior without the primer. And what exactly primer does?
Tanx!
Old 09-01-2003, 10:40 AM
Forhod's Avatar
Forhod Forhod is offline
Primer " holds " the paint to the plastic. I guess priming the interior is not always neccessary, it is all up to you. But the body is neccessary to me
Old 09-01-2003, 03:11 PM
Tea Tea is offline
Tanx!
depends, if you are painting something light over dark-based colored plastic (ie, flat red over black plastic) then primer will help greatly
primer provides a good rough ground for the paint layers to grab on, also it covers the dark base color so you dun have too much difficulty covering it with paint
Old 09-01-2003, 04:20 PM
"P-Man"
I only do the bodies to cut down on the cost as primer is getting very expensive to buy.
Old 09-02-2003, 09:22 AM
D.J.'s Avatar
One more thing. Did i screw up when i bought this type of paint? Guess ill have trouble cleaning the paintbrush
http://freeweb.siol.net/vmurko/colors.JPG
