Old 08-31-2003, 10:03 AM
blade34609's Avatar
blade34609 blade34609 is offline
Crazy ECU Codes!
Hi,
As you know I just finished my MPFI swap and I still have problems.
Its drivable but barely, you dont wanna go to far with it. (or fast)
Anyways I counted the number of blinks on my ECU and heres what I got:
1: Oxygen Content
4: Crank Angle Sensor
5: MAP Sensor
6: Coolant temp
7: Throttle Angle
10: Intake Air Temp
12: Exhaust Gas Recirculation System
13: Atmospeheric Pressure
15: Ignition Output Signal
I know there are alot of codes, the good thing is it starts right up and idles decently.
Please help, I gotta get this car outta my garage.
Thanks Alot.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-31-2003, 02:30 PM
caminsc5 caminsc5 is offline
Send a message via AIM to caminsc5 Send a message via Yahoo to caminsc5
i just did a zc swap in si and i am getting some crazy codes. (i have the si ecu for now, zc ecu will be here on tues). i am getting:
1--oxygen sensor
3--map sensor
5--map sensor
15--ignition output signal
i know that my vacuum hoses are hooked up wrong, dont know how they go though as for everything else i have no clue why i am getting the codes
Old 09-01-2003, 02:46 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
dude u must have really messed up on your wiring, or theres alot of shit bad on the mpfi parts u got or your ecu is bad.
did u try and pull hte hazard fuse and see what codes u are getting, just to make sure its not codes that were already on the ecu. try reset it
Team Lonely Drivers
Old 09-01-2003, 02:51 AM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Check your MAP Sensor and your O2 sensor. If those are both good, it's probably your wiring, 'cause I think both of those will throw the majority of the codes.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 09-01-2003, 02:22 PM
the other day, i looked at my ecu and it wasnt giving no codes or anything. and i got in the car and cranked it up, and something just told me to look at the ecu. i did and it was giving me those codes.
Old 09-01-2003, 06:39 PM
its weird taht u are getting a code 15 ignition output but it still starts up and runs fine. u should try run another ecu. because usually a code 15 if everything is hoooked up correctly is your ignitor, u wont get any spark if your ignitor is bad
Team Lonely Drivers
Old 09-01-2003, 06:43 PM
well i will get the zc ecu tomorrow and im gonna hook it up and see whats it says
Old 09-02-2003, 03:31 PM
i just got an ecu, i thought it was going to be the pm7 sut it wasnt it was the pr5.......is this from an LS?
anyways i hooked it up, and now it is giving me codes:
6-engine coolant temp sensor
10-air intake temp sensor
20-electrical load detector
does anyone know how to fix these or why they might be saying this? thanks
