a/c problem help me out...
My a/c all of a sudden doesnt blow cold, what the hizzle, its on and working i see the fan working and the belt turning and shit anyone know whay it would all of a sudden do this??
Keep it real, and share the knowledge..... Say NO to Primer!!
Does the A/C compressor click on?
Who needs A/C anyway? |
central cali people need a/c!!! it is on i assume if belt is running and fan is going
It would be faster
The belt is always turning, when you turn the A/C on the compressor should click on along with the fan. check your fuses & relays - hopefully its something as simple as that. |
either that or it just might need a recharge
Julian |
mine blew AGAIN a few days ago ... ive fuckin had it with the shitty a/c system these damn cars have.
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
well i found the condensor relay and that was still good, is there any others to check? this sucks way bad
dual pressure switch
clutch relay/condenser relay thermostat switch a/c switch fuses Have an A/C pressure test done. does the compressor click on? |
Re: a/c problem help me out...
i checked the fuses and i dont know where any of that other stuff is so feel free to elaborate you kick ass
the clicking he is refering to is the compressor clutch engaging.....have someone turn on the ac while there in the car as you look at the compressor....see if the compressor clutch engages and the compressor starts turning.
Yep what he said, the center part will start turning. Once we know if its engaging then troubleshooting will be easier, possibly.
Your compressor blew! if your in cali call hap recycling or go to there website haprecycling.com....good luck...you'll have to change it out and recharge the unit..if you totally not sure go to autozone and buy the tester kit and put the pressure gauge on your low side and if there's no pressure it's exactlly that.
Peter S. www.kutsujuracing.com |
