Old 08-30-2003, 11:46 PM
blade34609's Avatar
blade34609 blade34609 is offline
MPFI swap Problems
Hi,
My MPFI swap is done.
However the car idles way too high at 2000 RPM.
So I tried adjusting the cable and idler screw.
Didnt affect it any.
So I looked behind the MPFI intake manifold and saw 3 holes where air was being sucked in.
I put a pice of metal over those holes with 2 10mm screws.
It holds it in place, and it now idles perfect at 900-1000 RPM.
Not 2000 RPM.
But the car still wont rev past 3000 RPM.
I read somewhere that I am missing the
"Fast Idle Control Solenoid Valve"
Its supposed to have a hose from that im missing on the manifold.
Also, when driving I have no power whatsoever.
My car is slower than b4 with the DPFI.
Please help me ASAP!
Thanks A Lot.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-30-2003, 11:53 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
http://www.fourthgenhatch.com/mpfi.html
Are you sure your plugs are in the right spot?
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-31-2003, 12:11 AM
blade34609's Avatar
yes, I checked them and they are.
I musta wired the injectors and the dizzy correctly if it runs, correct?
I am missing the Fast Idle Solenoid Valve.
cause they are threads where 2 10mm screws fit perfectly into.
I was reading you are suppsoed to have one, in order to run.
Do you have one, on the back of your intake manifold?
this goes from the Purge solenoid to the small port next to the EACV on the back of the manifold
Cause as soon as I cover those holes up the idling goes to a nice idle.
Not a 2000 RM idle.
Thanks
Old 08-31-2003, 12:54 AM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
like i tell everyone else, when its something technical like that and ur not 100% of what ur doin just let a professional do it.....!
just my opinion....!
Y LOOK FAST WHEN YOUR NOT?????????
Old 08-31-2003, 05:15 AM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
what if he wants to become a professional and do it for his friends too?
Old 08-31-2003, 10:53 AM
gsf1200m gsf1200m is offline
The fast idle thing you are talking about has a plug coming off it right?
Where does this go to?
Old 08-31-2003, 11:50 AM
EFStali's Avatar
EFStali EFStali is offline
Send a message via AIM to EFStali Send a message via Yahoo to EFStali
since were on the subject of idles, my car has droped to 100rpms, but I cannot find the idle bolt for the life of me. I need help asap.
Name is Adam
Old 08-31-2003, 12:22 PM
no all im saying is dont do it a daily driver car.
Old 08-31-2003, 01:20 PM
blade34609's Avatar
Re: MPFI swap Problems
I think my intake manifold is missing that piece. It is called the Fast Idle Solenoid Valve.
It is supposed to be right behind the intake manifold. I think it has a hose that goes to it also.
There are 3 holes 2 of them are for 10mm bolts and i guess the one in the middle is for the solenoid.
According to a repair manual I read it says:
is used to increase air flow for fast idling at extremely low ambient temperatures.
Im gonna take a trip to the scrapyard hopefully Monday if they are open and get that piece.
Hey if any of you guys could take a quick pic of behind the intake manifold on the MPFI one it would be greatly appreciated.
So I can see what the Fast Idle Solenoid Valve looks like.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-31-2003, 01:37 PM
1MYSTIKLXI's Avatar
1MYSTIKLXI 1MYSTIKLXI is offline
It's raining here or i'd snap couple shots for you. I'm about to snatch apart a stock CRX SI engine. But it keeps raining when i go to do it. God must like this CRX or something lol.
"GOT BOOST?!?!?!?"
Boom & Rice ! What a delightful combination !!!!
