Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-29-2003, 11:49 PM
toasted8x's Avatar
toasted8x toasted8x is offline
Camry 94' rear brake conversion
How is the best way to start a Camry 94 rear brake conversion?
What do I need to do t start to finish this conversion on this old camry?
From drum brakes to disc brakes.
All in all, I'm trying to stop a little quicker, because of the freaks on the freeway.
Advice is GREATLY appreactiated, sorry for my spelling.
Old 11-17-2004, 01:40 PM
cschilling cschilling is offline
Re: Camry 94' rear brake conversion
This is EXACTLY what I want to do as well, only for my 95 I4 coupe. I'm curious as to whether I can simply replace the hub/spindle/brake assembly with matching parts from, say, an V6? Or is there more involved?
Old 11-17-2004, 05:33 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
I'm not up on what's necessary for the conversion, but my 94 XLE 4 cylinder with antilock brakes came with 4 wheel discs. You may start by looking at a boneyard for a 94 4 cylinder with antilocks and compare what you need to what's on your car now and try to buy those items off the boneyard car. Maybe take a few digital pictures of your rears and the proportioning valve and take them with you. I would also check the numbers on the proportioning valve in your car and the possible donor car and compare them to see if the valve is the same or different.
Good luck with the project.
Mike
94' Rear Brakes sathed Shadow 1 10-05-2009 08:31 PM
87-91 Camry Rear Suspension Parts F/S nohablaingles Classifieds 0 07-02-2009 11:22 AM
1995 Eclipse Rear brake conversion zerimar Tires and Wheels 1 05-23-2003 06:06 PM
Rear Brake Conversion? Keoki42003 Accord/TSX/Accord Hybrid 2 04-08-2003 11:16 AM
'90 Accord EX rear brake conversion KaotiXcorp2 Accord/TSX/Accord Hybrid 0 12-06-2002 01:55 PM
