Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-29-2003, 06:37 PM
grncivicdhr's Avatar
grncivicdhr grncivicdhr is offline
AF Premium User
Send a message via AIM to grncivicdhr
Question 240 brakes...
i'm comparing prices on brake upgrads right now. i've heard that you can get 300zx brembo rotors redriled 4 lug for the 240sx. if this is true, where can i buy these rotors? if not can a shop do this for you? any help would be appreciated and i'll share all the info i find out on any brake up grade (the spec-v idea included).
Old 08-29-2003, 07:23 PM
klohiq's Avatar
klohiq klohiq is offline
You can get 300z brakes from a junkyard for a pretty cheap cost...make sure you get the ones you want though since there are a few variants. A shop can drill a new 4 hole pattern on them for you or better yet you could upgrade to 5 lugs which is a better idea, even though it costs a little more. If you're tight on cash though then go with the 4 lug, just make sure the stock rims will have enough clearence I know stock s14 se (5 lug) rims will clear it, not sure about all the rest...
Infiniti Q45 brakes should also work, but I'm not sure how easy they are to install...
http://www.nissanperformancemag.com/.../240sx_brakes/ - conversion howto
http://importnut.net/300zxbrakeswap.htm - another swap
http://www.princeton.edu/~asad/zbrakes/ - brake caliper comparison
Old 08-29-2003, 07:28 PM
AF Premium User
thanks for the info. a 300z upgrade won't work with stock s13 240 wheel but i bought a set of 17s so it souldn't be a problem.
Old 08-29-2003, 07:37 PM
klohiq's Avatar
17" rims are perfect on a 240sx
Too bad I can't find exact copies of the stock s14 rims in 17"..probly just go with the crowd and get TE37s or something similar, either that or 5 spoke, 5 double spoke, or 6 spoke that look nice.
Old 08-29-2003, 08:42 PM
Suislide's Avatar
Suislide Suislide is offline
yeah, you can find them pretty much anywhere...a junkyard, eBay. hell you could even go into Nissan or a parts store and order a brand new set, although that would cost more. are you looking for calipers too? it's usually a good idea to upgrade everything when you upgrade one thing.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 08-29-2003, 08:55 PM
AF Premium User
i've found the calipers and rotors both on ebay and seems like i can pick them up for alittle over $400. project silvia haas stainless steel brake line you can use with the z32 calipers as well. right now i'm just looking at what everything will cost me.
1993 Cavalier wheel locks up brakes amphib72 Cavalier Problem Diagnosis 2 03-16-2010 09:28 AM
91 Ciera brakes WAAAY too sensitive vbettiga Cutlass Series 2 03-07-2009 01:57 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
