Go Back   Automotive Forums Car Chat > Nissan > Nissan 350Z/370Z | Infiniti G35/G37 Coupe
Nissan 350Z/370Z | Infiniti G35/G37 Coupe Includes the VQ35DE, VQ37VHR - Z33 and Z34.
Old 08-29-2003, 11:06 AM
Paonessa Paonessa is offline
Weapon R intake killed my Mass airflow sensor
just put my weapon r dragon intake on my 02. all was well for a while, i drove around for like 30 miles just listening to it, then i drove to school and to my friends house, about 75 miles in all. then just out of the blue i was driving and i nailed the gas and at around 5000 rpm as it switched to the second intake runner the car felt like it popped out of gear and it just stalled out on me. I couldn't get it to start until i disconnected the plug on the airflow sensor, and even then it will have a rough idle and won't rev over 2500 rpm even if you reconnect the plug while it's running.
so i took the intake off and returned the stock aribox and as i expected i still had the same problem.
in my opinion the Dragon air filter was quite greasy out of the box and i was wondering if it's possible for the sensor to have gotten covered in filter oil and therefore can no longer function properly. now i know i'm not the first person in the world to get a Weapon R dragon intake and put it on a VQ35 so has anyone else run itnto this? What options do i have to remedy this, other than buying a new airflow sensor? i can't imagine the sensor "blew" due to excessive airflow. please, help your nissan bretheren out.
Old 10-06-2003, 08:36 PM
badassz34 badassz34 is offline
Your MAF sensor is most likely just coated with excess oil from the reuseable air filter element. Clean the MAF with cotton swabs and denatured alcohol (rubbing alcohol, basically). DO NOT use carb or intake cleaner on the MAF. If you do this, and reset the computer by disconnecting the negative lead from the battery for ten minutes or so your car should run fine. I have never seen a maf actually damaged by oil or debris film. mechanical damage, however, such as the intake swallowing rocks and small woodland creatures, now that could do some damage.
Old 10-08-2003, 06:48 PM
z33guy's Avatar
z33guy z33guy is offline
Send a message via AIM to z33guy
it killed the one on my maxima to, cleaned it and it was fine.
'96 Jetta Mass Airflow Sensor anton-99 '91 - '96 5 04-05-2004 11:43 PM
Where is the mass airflow sensor? twangboy Engineering/ Technical 2 03-09-2004 06:49 PM
Cleaning Your Mass Airflow Sensor Nexagen Engineering/ Technical 5 03-04-2004 04:16 PM
Weapon R intake killed my Mass airflow sensor Paonessa Altima 0 08-29-2003 10:56 AM
Mass Airflow Sensor and fuel pressure quad4z26 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 04-26-2002 07:32 AM
