Old 08-29-2003, 09:12 AM
blazer1994 blazer1994 is offline
Angry 94 Blazer 5.7 Missing and Hesitates when Excellerating
Hi All,
I have been having a problem with my 94 Blazer 5.7, Automatic, 205K miles.
No problem starting, but when started first thing in the morn, it idles fine, but once on the road, and I excellerate it hesitates and almost cuts out, no power. Once it warms up, it seems to get better. But has rough idle, and still hesitates on excelleration.
Things Ive done or had done. Replaced plugs (couple of plugs were vry corroded), replaced Air Cleaner, used bottle of injector cleaner.
Took it to the dealer, they put it on the computer and no codes showed up, the first time.
The second time at the dealer, left it over night so they could see the problem when cold. They replaced Dist Cap/rotor, oxygen sensor, and fuel filter. But I am still having the same problem. I am wanted to get a little smarter before going back to dealer again.
Any ideas????????
Help would be most appreciated!!!
Old 09-01-2003, 01:36 AM
MarkB MarkB is offline
Mine does the exact same thing, Different vehicle but same problem.
I have replaced tons of sensors and checked a number of systems ie. oil pressure. spark ect.
No one knows the reason why this demon is doing what it is doing. It has even gotten to the point of stalling and backfiring. Only in the Mornings though. Or when competly cold. My next check is the PCM or injectors and injector electrical harnesses. Make sure you have no Vacuum leaks first.
Good luck let us know how you make out..
Old 09-02-2003, 05:37 PM
V-8Fan V-8Fan is offline
I hate to make the impression that I blame the EGR Valve for everything, BUT!
I would suggest that you disconnect the vacuum hose (and plug it) from the EGR Valve some morning and see what happens. The return spring in the valve gets weak and the valve opens too soon, and you have problems. Give it a try, it costs nothing.
1996 gmc 5.7 won't start-no spark 600cuin Sierra 5 11-13-2009 12:03 PM
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 11:55 AM
94 Blazer 5.7 Missing and Hesitates when Excellerating blazer1994 General Discussion 2 03-15-2005 09:58 AM
PROBLEM FIXED!!! 94 Blazer 5.7 Missing and Hesitates when blazer1994 Blazer 0 09-30-2003 11:07 AM
94 Blazer 5.7 Missing and Hesitates when Excellerating blazer1994 Blazer 1 08-30-2003 11:55 PM
