Stang
My freind got like a 88 or something stang with a 4 banger! im just wondering how easy a 302 swap will be. i know that we need new mounts but will the tranny bolt up? and what else do i need to know.. im more of a rice rocket person but im lookin at a new gt! and i want to understand stangs
Not very hard. Just get the wiring harness, computer, and motor; you might want to invest in a new tranny, too.
Swapping the motor is the easy part! It's all the odds and ends that will get a little more involved. You will need motor mounts, fuel lines, all wiring harnesses, computer. That's the bare minimum that will be required. The tranny will work, but you will end up cooking it in no time. Other things that should be replaced are all suspension components, rearend and drive line.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
it very well might be cheaper to purchase a 5.0 then to do a swap; unless you get the hook up on the 302 anyways.
free hypsi87!! Dan's White Horse Bring back Melt Crew 002 - 3657 posts can't be wrong! |
That seems like a shit load of dirty work for nothing.
Re: Stang
Re: Re: Stang
sorry this is late but ive been busy.. just get a gt and work on it.. shit when u can by a stang for 400 dollars that runs fine who gives a crap...its easier to by something like that and make it into a lil sleeper than actually getting a gt with higher insurance rate and building that
4-cylinder conversion
I am in the middle of a 2.3 to a 5.0 conversion currently. The engine swap is easy as mentioned previously. It's the other stuff that's tedious. Jason Fletcher has a decent piece of reference material for starters'. The easiest way to do this is using a carborateur (sp?). Need to swap the following at a min.:
Motor Mounts, brake system (front), brake lines (4 cyl. routing is different), struts, spindles (different geometry), transmission (4 cyl wont hold up), tach (will read wrong), rotors (upgrade to 11" rotors), calipers, wiring harness and computer, rear end, brake booster (optional), springs (optional), rims (11" calipers will interfer w/ 14" rims or smaller-need 15" rims or larger), strut tower plate (changed by manufacturer between 1989 and 1990), etc. Hope you've got an air compressor, it's been allot of work so far. |
