Old 08-28-2003, 04:50 AM
DaICeMAn's Avatar
DaICeMAn DaICeMAn is offline
Send a message via AIM to DaICeMAn
Question Help with a 91 Eclipse
I have a few questions. I just bought a 91 eclipse for 200$ the tranny houseing has been cracked and twisted it looks like mabey a mount is bad well i just got a tranny from a u-pull-it junk yard i hope it fits lol i know 91 made 2 diff trannys 1 with a 22 tooth and one with a 23 tooth spline but my question is this its had a upper engine rebuild and on the valve cover it says 1.8 that someone wrote but the sticker on the hood says 2.0 well i pulled a 1.8 tranny do these engines have the same block?? and can i do a head swap to make it a dohc?? this is my frist post so plz some one help ty
Old 08-28-2003, 05:54 AM
DaICeMAn's Avatar
Also
Is there a visual way to tell witch engine it is in there the 2.0 or 1.8 ?? i hope they didnt do a swap lol also ima new to dsm but whats the deal with the 1.8 and 2.0 are they the same block with diff heads or something to that effect ?? and if mine does have the 1.8 should i just junk it lol is it realy worth trying to get power out of this is my first import im messing with so and comments will help thanx
Old 08-28-2003, 12:58 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Yeah the 1.8 is garbage. The 2.0 says DOHC on the valve cover with the spark plug wires running down the middle of the valave cover. The 1.8 has the spark plug wires near the back of the V/C. I'm sure they are different blocks, and I'm almost 100% the 2.0 head doesn't bolt on.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 08-28-2003, 02:05 PM
DaICeMAn's Avatar
Thank you
Yes it seems it does have the POS 1.8, but i alreay bought it and i payed 200$ for it and 35$ for the tranny witch aint to bad. Ill prolly just sell it for 1000$ real quick to someone who need a good running car. Ohh it also have a rebuilt head so that might make it sell quicker but thanx for the help. Ill still be around posting because i might pull a 2.0 at the junk yard for 125$ and 50$ core charge cheap and do a engine swap. The car is in real good shape might be worth it to swap motors. What do ya think?
02 camry (my girls)
95 trans am (lt1)
04 neon (Moms)
89 cparice
Old 08-29-2003, 02:21 PM
fast1.8sohcdsm fast1.8sohcdsm is offline
Re: Help with a 91 Eclipse
I don't think the 1.8L is garbage, it was a cheap alternative for someone to have a nice car, but a good economy car at the same time. As for the power, yes 92 horsepower is quite low. But the engine was cutt back hard core from potential. If anyone can remember back the 4G32/G32B were turbocharged SOHC 8 valve engines. These were before the 4G63, and shown an okay potential. The 1.8L is the same engine with 9:1 pistons, a lower rating oil pump, higher flowing cylinder head, and higher displacement then the G32B/4G32. The stroke, crank, rods, and everything else is exactly the same. This engine was turbo at one time, just a better engine was produced with greater results. If it were never to come, who knows if the 4G32 would have been the powerhouse for the 1G Eclipse.
Old 08-30-2003, 10:44 AM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
Actually , I've read of a few DOHC head swaps on the 1.8's. Dunno actually if it was BS or not. Also , supposedly , the 4G63 crank can be added to stroke it to a 2.0. I don't really know enough about the 1.8 to know if thats possible or not , though.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 08-31-2003, 01:38 PM
Re: Re: Help with a 91 Eclipse
No, the 1.8L has different sleeves then the 2.0, and it is skinnier. It won't work. End of discussion.
Old 08-31-2003, 10:56 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Re: Re: Help with a 91 Eclipse
Well thanks for gracing us with your infinite knowledge. This attitude really annoys me. Especially when one calls a smaller bore dimension a "skinnier sleeve." Maybe I'm just on the rag today, who knows...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-01-2003, 02:16 AM
Re: Re: Re: Re: Help with a 91 Eclipse
I think you have had alittle too much caffine. But if it makes you feel any better, I can blame it on your stupidity with 1.8's. You probably thought the heads would work And I wasn't talking about the sleeves being skinnier, I am talking about the WHOLE block being skinnier. For those who get confused, I guess I need to explain in more detail.
Old 09-01-2003, 03:27 AM
AF - Advisor
Re: Re: Re: Re: Re: Help with a 91 Eclipse
Dont confuse my potential "stupidy" with 1.8s with your stupidity for owning one, or the excercise in futility that is trying to mod one But back to the matter at hand, I believe RockinWRX was thinking of poeple using the 4g63 head/4g64 block hybrid perhaps. I've never heard anyone doing the 4g63 head on the 1.8, but then again, who would waste the time. I still think you mean to mention the bore dimension is smaller, not the sleeves are skinnier. But if you dnt know what you are trying to say, how should I be able to figure it out
Kevin Jewer
Old 09-01-2003, 03:31 AM
Infact, since you have said that statement, from this day forward I will continue to build this engine to run faster times then yours
Old 09-01-2003, 03:34 AM
Talon007's Avatar
Holy fuck dude, 95GSXracer hasn't even posted anything about the 1.8. He corrected you, when you used the term skinnier, is that technical term I havent heard of? If you meant to say the whole block was skinnier you should have sad more narrow, or even said the head bolts in the block won't match the 2.0L head. And yes I get confused when you use a vague description like that. Mabey your the one who needs an attitude adjustment, just because you have "one of the first" 1.8 Turbos out there doesnt mean your king shit.
Chris Clark
www.Talon007.com
Old 09-01-2003, 03:36 AM
I believe Narrow and Skinny are the same definition. If I were to say more Narrow, I would infact would have thought of the sleeves. 95 GSX doesn't know shit about a 1.8L, and should stay off posts when concerned about a 1.8 4G37. Let the ones who actually built the engine to help others. As for you, my 1.8L Garbage may be the next worry against you on the track.
Old 09-01-2003, 03:41 AM
Talon007's Avatar
So skinny sleeves is the new technical term for the bore diameter of a 1.8 4G37?
Not once did 95GSXracer say anything technical about the 1.8, both RockinWRX and I said something.
Sure your car maybe fast, I'm up for a challenge, but I bet I spent way less money than you did achieving the same goals
Chris Clark
www.Talon007.com
Old 09-01-2003, 03:44 AM
We are totally getting off topic on this post, but I will reply with this last statement.
My goals are totally off your goals. My goal started when I changed the engine from a Natural Aspirated engine to a Turbocharged engine. THe day I have this engine run low 11's will be a miracle. ANd the day I do that, you can gaurantee that even though I have spent more money they will look at my setup more superior then yours.
Need Help with Eclipse 5331 Security Madasljj Car Audio 9 08-01-2012 11:52 AM
Help with Eclipse PappaBlue Off-Topic 0 05-31-2004 06:25 PM
help with eclipse trooper1822 Off-Topic 4 11-18-2003 10:50 AM
