Old 08-28-2003, 12:15 AM
projoe21 projoe21 is offline
Talking ok i need some help your pros!
ok i need some help.i have a 1992 eagle talon non turbo..and ill be driving and all of a sudeen my idle drops from 1000 to like 500 and the check engine light comes on and i have no power..but then when i give it alot of gas it breaks out of it and then keeps cutting out when i drive...please i need help guys!
Old 08-29-2003, 08:52 PM
boots03 boots03 is offline
Send a message via AIM to boots03 Send a message via Yahoo to boots03
lol...sounds like my car. tomorrow i'm replacing the IAC motor and the TPS in mine. and hopefully that problem will finally stop.
Old 09-05-2003, 03:32 AM
firefighter81 firefighter81 is offline
Send a message via AIM to firefighter81
I had the same problem with my Turbo 92, and I don't see why the same thing couldn't happen on a n/t. Check your ECU....take it out, take off the metal cover and smell it. If it smells like rotten fish your ECU's caps are leaking, and ruining the ECU, mine was bad enough to where there was actually burn marks on it. Caused all sorts of weird problems. I tried everything, before actually checking the ECU, picked up a used turbo ECU for $75 and it ran fine till the day I sold it.
Jason
Old 11-12-2003, 12:09 AM
honeecone honeecone is offline
Re: ok i need some help your pros!
my car is doing the same i start it and the light comes on and i have know power then i have to rev it up to get the engine light out and then i got power again
Old 11-12-2003, 12:11 AM
please help me
Old 11-13-2003, 09:47 PM
hi im having same problem just had in on a machine today and they told me that it was a code 44 ignition signal
Old 12-26-2003, 08:29 PM
Jason
what is ECU and where do i look for it
Old 12-26-2003, 08:47 PM
ECU is in the glove bod i think, and it controles the car basicly
thast extreamly dumbing it down
Old 12-28-2003, 12:30 AM
Re: Re: ok i need some help your pros!
did you mean glove box
Old 12-28-2003, 03:17 AM
ya i did, i couldnt spell last night, my bad, and i was wrong, i was thinking of my Z24, i have no clue where the ECU is on that car, i never did look for it on my old talon
Old 01-07-2004, 12:54 PM
W-44Olds W-44Olds is offline
1992 The ecu is behind the cover where the heating vents are in the middle.To remove that take the screws out at the bottom and left side and also pop out the vents above the radio.There are some screws that have to come out.Remove the heat control knobs and then the cover.Then look for the box in there you can't miss it.
Old 01-07-2004, 07:54 PM
MrZ's Avatar
MrZ MrZ is offline
The ecm is actually standing up directly underneath the radio. You need to remove the front carpeted panels under each side of the console, no other panels need to be removed. The carpeted panels are held by two screws on each side, they are covered by a round plastic piece that matches the carpet color, it's about 1" in diameter. They pop out with a screw driver.
The ECM itself is held in place with two screws on each side, which are accessible once you remove those carpeted panels.
It doesn't make much sense to remove it unless you know it's bad. The right thing to do is to get the fault codes from it, which I explain in another post in these same forums, if you need a link to it I'll find it. Anyway, you need to find out what sensor or device is causing the problem, and that can be determined by the fault code.
Mark
Old 01-08-2004, 03:02 PM
ok i dont no for sure if it's the ecu but i had one ingintion coil put in there r 2 so cant tell if they are bad but my code said 44 i am still having trouble with my car it has know power it will bog out on me and the i have to rev the car up or put it in nectural and rev it to get my power back so i can go this is consent but if i leave my car run for at least a 1/2 hour in the cold weather it wont bog until i shut it off and have to start it up again to go but in warm weather i can start it up and it wont bog the whole time i drive it i have already spent 8 hundred in trying to get it fixed and am slowing giving up please help it is a 92 eagle talon non turbo
Old 01-08-2004, 03:11 PM
Mark
i have a 1992 eagle talon non turbo 2.0l i just had a computer module and a oxygen senor put in ,and now my car is still not running right someone told me it has to do with a coil but what coil and how do i know for sure that's it .when i start the car it is fine untill i get moving the engine light comes on when i lose power and then it bogs out on me and the car won't go so i put the car in netural and rev up the engine while im moving and the engine light goes out then i have power again to get going ,but does this all the time i have to keep doing this every time i go somewhere. can someone please help me
Old 01-08-2004, 03:28 PM
Re: Re: Re: ok i need some help your pros!
[i have a 1992 eagle talon non turbo 2.0l i just had a computer module and a oxygen senor put in ,and now my car is still not running right someone told me it has to do with a coil
my car is mannal i thought that the car wouldnt start at all if the ignition power transistor was bad but i did change one of the ignition coil and it still bogs out and no power but when i let my car run for say 1/2 hour . before pulling out it runs fine but to just start it up and go i have the engine light comes on and no power to go have to put it in nuteral and rev it out to get power the whole time i an driving my car it does this it is drving me crazy so far i have about 8 hundred in it running out of money anything that you can think of that i need to do to my cari now got your mind all messed up lol sorry
Getting some detail done, need some help FireFromTheGods Exterior | bodykits | Lighting 0 10-06-2004 11:00 PM
need some help resizing some pics for my sig twdz28 Camaro Discussions 2 09-02-2004 01:50 PM
Need some help findin some parts. slammina98blazer Blazer 5 03-02-2004 08:03 AM
Need some help from some one that can make custom PE parts. Jon MW Car Modeling 1 10-20-2003 10:33 AM
i need some help on some rims jays87 Tires and Wheels 10 05-07-2002 11:32 AM
