| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
timing belt
i have a 90 civic d15 block but with a 95 d16z6 vtec head, n i need to put a timing belt on to finish the swap, now the prob is do i get a 90 belt or a 95 belt?
search the part number for the two engines, I think they probably have the same part number, may be 1 number off (but I believe they are the same).
The best way is to go to the part store and compare the two belts (length and width) and see if they are the same. Another thing to pay attention is to check for the "teeth" of the belt to see if it will match the gears. M ake sure you install the belt correctly, cause if you skip a "teeth" on the cam gear, it will make 11-12 degree off the cam timing.
Power is nothing without control The fastest driver is the one with skills 95 Civic EX 83 Toyota Starlet 07 Ducati Monster S4RS |
think ill try that thanks....let u know if they r the same or not....
get the 95 belt.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
