Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 08-27-2003, 06:47 PM
strodda strodda is offline
bumper paint touchup
i had to do a little painting on a bumper, and the touchup kit i bought came with the factory honda black paint and a universal clearcoat. i noticed today after it dried that the paint i applied(with the brush applicator) is a little streaky. is there anything i can do to smooth it out a little without scratching off or affecting the color of the paint? maybe a soft steelwool or some kind of sandpaper.
Old 08-28-2003, 08:06 PM
bdt09's Avatar
bdt09 bdt09 is offline
i wouldnt use anykind of sandpaper or steel wool, you could try using a high speed buffer with a compound, wipe it off and then use a polish wax, that might help.
Old 08-29-2003, 05:30 PM
Duatone Duatone is offline
if you want your touch-up job to look really good, though this mainly applies to chips and heavy scratches, is apply enough paint so it is just slightly high than the rest of the surrounding paint, let cure, wet sand LIGHTLY with 2000 grit, and i mean lightly, then polish and repeat with the clear, if you happen to sand through, just re-apply the paint and try again. this is the right way to do it.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
