Old 08-27-2003, 02:03 AM
mengy mengy is offline
Will 92-95 back lights fit?
from a coupe fit into a hatchback?
from a sedan?
Old 08-27-2003, 10:34 AM
LOK[R9] LOK[R9] is offline
I might think so .. but what is sure is that the back turning light arent interchangeable!
LOK out.
Old 08-27-2003, 07:15 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: Will 92-95 back lights fit?
from a sedan?
The 92-95 Coupe and Sedan share the same tailights, so they are interchangable. The hatchback has different taillights. Basically, A Coupe and Sedan can interchange the rear bumper and tailights with each ohter, but not with a hatchback. However, a Coupe and Hatchback can interchange front bumpers, but a sdean can not with these. Not sure if this includes headlights.
Old 08-27-2003, 10:41 PM
mtdxx mtdxx is offline
but will the sedan/coupe tailights still attach to a hatchback and still work, like will the bolts line up and all? ( I realize they are not the same shape and probably would not look right, but would it be possible?)
Old 08-29-2003, 06:06 PM
Honda God
That I do not know, but I wouldn't try it. Let's face it, if the shape is wrong, the gasket seal shape is probably different too. That being said, if the gasket seals don't fit right (I am refering to stock ones, using aftermarket seals always leak, no matter the car their on), the you will have a leaky back end. You can try it, I could be wrong, the bolts may line up, the gasket may keep water out and prevent leaking, and all you may have to deal with is improper fitment and big gaps as a result of the slightly different shape. It's not worth finding out in my opinion, but if you want to try, or have the lights already, go ahead. As long as you don't force it and brake anything, its completly reversable if it doesnt work.
Old 08-29-2003, 08:20 PM
I won't be trying it, I guess the idea was just one of my "brain farts" or whatever they call them.
I actually did replace my back tailight a month ago or so, but it came off an identical car at a junkyard. (I backed into another car in my driveway, that parked car just fell right out behind me when i was backing up)
Old 09-24-2003, 10:17 AM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
92-95 civic headlights will fit ALL makes and models ex, coupe, sedan, dx, HB. everything else is true.
Old 09-30-2003, 11:59 PM
r i c k r i c k is offline
Unhappy Re: Will 92-95 back lights fit?
so does this mean all i need to do in order to change my tail lights, is take the larger one (the one that doesn't come up with the trunk lid) along with my bumper, off? Because right now, that large light wont COME OFF.
Old 10-01-2003, 04:18 AM
Honda God
Re: Re: Will 92-95 back lights fit?
The tailights are held in by 4 nuts per tailight assembly. remove the nuts, the lights, and they should slide right out.
