Old 08-26-2003, 10:14 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
data loggers
like i have said before i am new to tuning modern engines and the dsm world, so data loggers just take readings from ure eco and store them so u can make adjustments, according to what it tells you, to the car when u go to tune correct?
so if i got that straight at what point in buliding my car up should i get one and what kinds would u suggest?
thanks
Old 08-26-2003, 11:16 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
The best route is the DSM Link, it data logs and you can tune with it. Check out www.dsmlink.com the new version is coming out soon, if its not already out. You'll need somesort of datalogger/tuning device after any significant mods like, injectors, turning up the boost, etc.
I wish they'd come out with a 1G version, that thing is so pimp
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 08-26-2003, 11:31 PM
95_GSX's Avatar
thanks for the link and advice.
Old 08-26-2003, 11:54 PM
95_GSX's Avatar
i looked on the website and i didnt ever see a price??? what did the first version run for price??? thanks.
Old 08-27-2003, 01:19 AM
Talon007's Avatar
$595 american
Chris Clark
www.Talon007.com
Old 08-27-2003, 01:55 AM
kjewer1 kjewer1 is offline
AF - Advisor
DSMlink requires an EPROM ECU which is a PITA to find. Early 95s should have come with one though. A more common option for both 1g and 2g is an SAFC, Pocketlogger (or TMO logger which is popular in the 1g), and larger injectors. Done properly this can also take care of fuel cut. DSMlink is the best way to go though. But I did fine before it came along... I fint it most useful for cars with a 1gina2g swap...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-27-2003, 01:58 AM
Talon007's Avatar
Well said, but it is nice to have all those in one. A very nice package IMO. I have to find a place for my SAFC and lug around my laptop etc.
Chris Clark
www.Talon007.com
Old 08-27-2003, 08:26 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
DSMlink is really good
but i'm going the AFC+pocket Logger combo
http://pocketlogger.com/?page=home
here's another good tuning link:
http://home.comcast.net/~tarryo/kyle/tuning.html
its very confusing at first
-Agim
Old 08-29-2003, 09:27 AM
AF - Advisor
hehe Kyle's one of the locals in my group, NEDSM. If you need any clarification on that post it on www.racingknowledge.org. Be careful though, he gets cranky
Kevin Jewer
Old 09-01-2003, 08:05 PM
boosted331 boosted331 is offline
Re: data loggers
Originally Posted by Talon007
$595 american
600 bucks for that? I'd just as soon save my money for an AEM at that price!
Old 09-01-2003, 09:57 PM
AF - Advisor
Re: Re: data loggers
I would MUCH rather have DSMlink than AEM. DOnt even get me started again...
Kevin Jewer
Old 09-02-2003, 07:49 AM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
For those of us stuck with a 1G ECU , I guess the pocketlogger or TMO is the way to go. But I thought the S-AFC didn't have enough adjustment to go beyond a certain point? I recall 95GSXracer saying that a while back. So besides the AEM , whats my alternative? Can the TMO go beyond the S-AFC? or does it have that kind of adjustability or can it even do that............. Sorry , when it gets beyond S-AFC territory , I get a bit confused.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 09-02-2003, 05:35 PM
Re: Re: Re: data loggers
Hey, your opinion. I've seen and used the EMS on a few cars, and I really liked it. Atleast it had tons of cells you could control, instead of a few sliders adjusting fuel and timing every thousand RPM's. Sounds like a gussied-up AFC.
Old 09-02-2003, 10:15 PM
AF - Advisor
Re: Re: Re: Re: data loggers
This shows your lack of knowledge in the field. But dont take that the wrong way. I hear people constantly saying this, the aem (or other standalone) lets you control many mor rpm points, does 3d mapping, etc. What do you think the stock ECU does? The stock ECU is VERY good at what it does. Dave Bushur ran 7s on it. It makes adjustments at any rpm point, a couple hundred tiems a second. Based on rpm, load, airflow, intake temp, coolant temp, throttle position, knock sensor, baro pressure, etc. Wheres the problem with that? When using something like an AFC, you can only adjust every 1k rpm, true. But the unit use some algorithms to interpolate between those rpm points, same goes for TPS in between the hi and low TPS set points. So between that, and the fact that the ECU does constant adjustment and monitoring, its the same thing hte standalone does. If you need more fuel contorl than every 500 or 1k rpm incrememnts, you are over tuning anyway. Fuel tuning should be done on a load basis (almsot entirely derived from airflow and rpm), which the stock ECU already does. I could go on further, but I'm at work. Suffice it to say that the ECU is very good at wht it does. Only slight tweaking of a few parameters is needed, and DSMlink provides everything you need, and nothing more. No added complexity. Tuning with the AFC, MAF translator, VPC, emanage, etc are all hacks, since they change the airflow signal to the ECU causing all kinds of odd annomalies, bu it works well enough for 7s. Standalones are ok, but I prefer the stock ECU and maps, with some slight tweaking in DSMlink.
Rockin, I think what you heard me say was about the range the AFC has. +- 50%. If you are using large injectors you use almsot all of it up. Lets say you have 660s, and you set everything to ~-35%. That leaves only 15% range left. You will likely be able to run about 5% lean on pump. SO that leaves only 10% now to lean out on race gas. Many people have gone faster on race gas by going to SMALLER injectors. If you are at the point where you have no chioce (my 660s are at 110% duty cycle for example) then VPC or the MAF translator will help get you some more range, but all at the expense of screwing up the airflow signal. DSmlink really is the way to go, since adjustments do not interfere with any sensor readings, and make changes to the actual internal maps.
Kevin Jewer
Old 09-02-2003, 11:39 PM
95_GSX's Avatar
hey thanks 95_GSXracer, that sounds like really good info to keep in mind for when i order my logger. thanks for the help.
