Old 08-26-2003, 06:17 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
B18C1 in crx
hey guys. i was doin some research, and was just thinking about doin all this. i think it's a pretty good idea. just wanna hear what you guys think.
JDM B18C1 in a crx. do all the upgrades for fuel management, what not and such. then probably slap a turbo on there. probably a
T4/T60-1 from turbonetics or something. this should probably get me into the mid 12's, right? let me know what you guys think
Old 08-26-2003, 07:29 PM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
B18c1 is CTR engine right?...if so yeah man that would make a nice combo for the crx, I am all for crx's and hatchies with B18 and F/I. Good luck and let us know how it works out, and yeah you can prolly hit 12's make sure get some nice light wheels and gut the back. then you should be set
Darrell
thegrumpysergeant.net
Old 08-26-2003, 09:52 PM
B18C1 is the GSR engine. i was probably goin to get the civic si rims. i like those a lot on a black crx. i don't wanna do anything too ricey. not to found of them. sorta wanna keep it a sleeper also.
Old 08-27-2003, 07:52 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the b16b is the CTR motor, the b18c1 is the GSR, anyway depending on how well you build up the motor and how much PSI it can handle, you should be able to hit the 12's in a crx.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-27-2003, 11:55 PM
boosted331 boosted331 is offline
Why would you want to use a fairly laggy turbo like a T4/60-1 when you only want to go 12's? And by laggy I mean lagging into the 5000+ RPM range. You'd go faster with something smaller like a T3/T04E because you'd be making boost sooner off the line, even if the 60-1 makes more power.
Old 08-28-2003, 08:10 AM
boosted, so your saying that the t4/t60-1 is too big of a turbo? if i got that turbo, what kinda times would i be running with that? thanks
Old 08-28-2003, 02:30 PM
Re: B18C1 in crx
A T4/60-1 is good for something north of 600 horsepower at the wheels. Wee bit too big for a stock GSR.
Old 08-30-2003, 09:28 AM
if i got stronger rods and internals, do you think then i could handle the T4/T60-1. the stock compression ratio on a gsr is 10.2:1, i think. Max boost i could probably run with that would be like 9 psi, right?
Old 08-31-2003, 01:40 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
i think the problem he is telling you about as well though is it wont spool up as fast as the smaller turbo on a little 4 cylinder engine. but ive heard 6-8 is safe for GSR, but if you are building the internals, might as well lower the compression a bit while you are in there, then put more boost.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
1987 Civic/CRX HF HELP jessenichols1991 '71-'87 Civic | CRX 0 05-01-2010 07:54 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
CRX DX Rear Bushing replacement rusted '88 - '91 Civic | CRX | Wagon | Shuttlee 10 08-19-2009 11:08 PM
