Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-26-2003, 12:42 PM
zenith's Avatar
zenith zenith is offline
Reset ECU / Air Intake?
Hey everyone, I got a quick question, stupid as it may be...
When installing an aftermarket air intake that replaces your stock air box, is it necessary to reset your ecu? A guy at a local shop mentioned this to me and I wanted to check the statements validity. The only sense I could make of it is that it might re-calibrate your MAF to work better with the new configuration? Sounds bizarre to me, but I just wanted to be sure I wasn't F*#@'n up my Maxima or miss'n out on some hp. Any info would be greatly appreciated.
Old 08-26-2003, 12:58 PM
KoRnboy KoRnboy is offline
Send a message via ICQ to KoRnboy Send a message via AIM to KoRnboy Send a message via MSN to KoRnboy Send a message via Yahoo to KoRnboy
That's news to me.
Zach
Old 08-26-2003, 01:19 PM
Paonessa Paonessa is offline
i've heard that too. it's bogus. i had an intake on my 95 maxima for 2 years. i had to reset the ecu cuz when i started the car up for the first time the plastic sensor wasn't plugged in right so the MAF wasn't working. the car started for a second then the rpm just dropped to zero and the CEL came on. that was the only instance. any other car i put an intake in(mostly nissans) i had no problems leaving the ecu alone.
Old 08-26-2003, 10:37 PM
EPVQ30's Avatar
EPVQ30 EPVQ30 is offline
resetting the ecu willl only make the computer take longer to learn the car's dynamics all over again.. there is no need to reset it.
SHIFT_99 SE-L 3 pedals
Old 01-27-2004, 12:37 AM
myke321 myke321 is offline
Re: Reset ECU / Air Intake?
How about after installing a y-pipe? Reset?
Old 01-27-2004, 02:27 AM
daddyhalk daddyhalk is offline
can some one help me?
Old 01-27-2004, 02:31 AM
87 maxima idles and revs fine in neutral or park.
put into any gear ,...it dies.......
just started tonight out of the blue.....help!
Old 01-27-2004, 12:46 PM
Max_PR Max_PR is offline
As EPVQ30 already stated, it is not required to reset the ECU for this mods. The ECU will automatically calibrate itself to the new intake and exhasut "settings" after driving it for some few miles. If you reset the ECU it will have to start this calibration all over again.
Old 01-27-2004, 01:05 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: Re: Reset ECU / Air Intake?
yup, that's what he said. 6 months ago when this thread was new and valid.
no you don't need to reset it after a y pipe either.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 01-28-2004, 01:00 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: Re: Re: Reset ECU / Air Intake?
its not required but is very helpful after doing any mods. i reset mine after i installed my intake and put in a new fuel injector and my redline increased to 6700 from 6400.
must be the ecu reset. i encourage you to do it after any engine modification, i dont care what anyone says
not required but may be helpful performance-wise.
438whp / 373tq - 11.9 @ 126
