Old 08-26-2003, 08:19 AM
TurboNutzz's Avatar
TurboNutzz TurboNutzz is offline
OBD II or OBD I
Alright this is probably one of the oldest questions in the book, I know that OBD I has less oxygen sensors and thus is a little easier to deal with when modifying....but is there really a need or an advantage to buying the harness to switch your car over to OBD I from OBD II? thanks again for the infos....just tryin to learn some shee.....
Old 08-26-2003, 11:48 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Yes, OBD I is easier to tune, so if you are planning on getting into details it is much easier. But at the same time, it is illegal to backdate emissions equipment, so if you live in cali you could be fuckered.
Old 08-26-2003, 01:39 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
My ctr is obd2 and has one o2 sensor.
Old 08-28-2003, 02:38 AM
S1 Type-R's Avatar
S1 Type-R S1 Type-R is offline
Send a message via AIM to S1 Type-R
They do this for more fuel....From what ive reasearched OBD1 throws in more fuel then ODB2....correct me if im wrong...
2001 ITR
WWW.SQUADONE.NET
Old 08-28-2003, 04:43 AM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
obd1 basically is simple, less emission standards so all it does is turn on when the engine warms up the coolant temp sensor tells it when to n it cycles, there is only 1 o2 sensor n that before the cat..n the check engine light is only set when there is an emissions related prob, obd2 has 2 o2 sensors which means for instance if u take out ur cat light goes on, n there r more sensors added to monitor emissions systems..obd1 is easier to fool when mods r made...obd2 is a lil more trickey to get around, lots of sensors set at certain specs...
Old 08-28-2003, 10:37 AM
Ricochet's Avatar
Banned
Re: OBD II or OBD I
That's not necessarily a bad thing is it? I like knowing the computer is keeping a close eye on what's going on in my engine. I don't have heavily modded internals though but I could see how that could be a headache...
