Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 08-25-2003, 12:54 PM
Heretoday Heretoday is offline
Trans/diff leak..procedure?
I have a '95 Altima GXE, manual trans 4 cyl with approx 165k miles on it. I've recently noticed some spots of oil on my driveway and an increasing whine noise from the transaxle. I crawled under and saw there had obviously been a bunch of leaking going on but could not figure out where from.
I drained it, cleaned as much as I could, refilled and went for a quick spin. Noise was much better, it was definately low. But when I returned I noticed it was leaking again already....a steady drip no less1
Seems it's coming from where the driver side half shaft inputs to the diff. I suspect it's merely a seal but I can't be certain.
Anyone ever heard of this or know of a procedure to replace that seal (if that is indeed the source)? I am very mechanically inclinded and have no problem doing the work, I'm more concerned about being able to do a bit of reading on the subject and whether or not my suspicion of a leaking seal is correct.
So, any help on this would be most appreciated!
Thanks.
Jack Money
Old 08-29-2003, 07:50 AM
98altima 98altima is offline
Get you a Haynes or Chilton manual.. it will help you out a lot. Sorry not familiar with that problem.
Trans/Diff not Engaging rjeffery Silverado 10 01-19-2010 09:56 AM
97 GT bad trans, diff bluestinger66 General Discussions 0 04-01-2008 10:21 AM
Help with trans/diff fluid swaps... stupid procedural/tool questions (PICS) Cobra4B GTRA / GTWS / GTS 2 01-23-2008 12:03 AM
maxima trans diff help mixmastabob4 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 09-04-2006 07:57 AM
Trans + diff or transaxle? andmoon Passat 0 04-20-2006 12:30 PM
