Old 08-25-2003, 12:45 PM
LoCoRaCeR LoCoRaCeR is offline
Send a message via MSN to LoCoRaCeR Send a message via Yahoo to LoCoRaCeR
CRX/Civic lights interchangerble?
Can anyone tell me if gen 2 crx lights will fit a gen 4 civic? cheers
J
BTW I did try searching but didn't find anything
Old 08-25-2003, 01:18 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: CRX/Civic lights interchangerble?
J
Yep, they do.
There's been several threads about it. You may need to swap mounting brackets, but the lights themselves fit fine. And, so do the brackets, but the problem comes when you try to put your corner lenses back in, they don't attach the same...
Old 08-25-2003, 01:55 PM
Sorry forgot to mention...
I was talking about the rear lights, any idea on these?
cheers
J
Old 08-25-2003, 02:31 PM
ci5ic's Avatar
Re: Sorry forgot to mention...
cheers
J
Definitely not.
ci5ic's Avatar
Er... More precisely, not without some $$$.
Old 08-25-2003, 03:36 PM
Sorry, whys that then? i am being a bit optimistic i guess but i thought they would work?
J
Old 08-25-2003, 03:41 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
Well the CRX center piece is smaller and, the keyhole is in the center piece on the CRX where as on the hatch the keyhole is under the center piece
KoRnSaQ
Old 08-25-2003, 04:06 PM
How bout other model lights?
That makes sense as to why they wouldn't fit then, lol. I've seen a couple of civics with what i think are integra rear lights? Can anyone shed light on this? i will have a search aswell see if anything turns up...
J
Old 08-25-2003, 04:45 PM
ci5ic's Avatar
Re: How bout other model lights?
Yep... swaps are certainly possible, but there's no direct swaps except from other 4th gens, like you could swap in EDM or JDM tails, or put 88-89 tails in your 90-91, etc. But, as with the CRX tails, all the swaps are possible, you just gotta be ready to shell out some serious dough.
Old 08-25-2003, 06:29 PM
Re: Re: How bout other model lights?
Is it the integra lights i seen moulded in on some 4g's? With the boot modified to flush to them?
J
Old 08-25-2003, 10:34 PM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Can u swap just the outer lenses from the HB or CRX to the 4DR?
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 08-26-2003, 01:20 PM
ci5ic's Avatar
Re: Re: Re: How bout other model lights?
J
Well, there are some with the teg lights, there are a bunch with prelude tails, skyline tails, whatever... it's all been done.
Not sure what you mean by "outer lenses", but I'm assuming you mean the actual light part on either side of the center reflector, and the answer is no. Not directly anyways, so you have to do some body work which = $$$
1987 Civic/CRX HF HELP jessenichols1991 '71-'87 Civic | CRX 0 05-01-2010 07:54 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
civic/crx tail light swap? Deadboy '88 - '91 Civic | CRX | Wagon | Shuttlee 0 04-30-2009 12:11 AM
CRX/Civic Dash Swap civicf/x '88 - '91 Civic | CRX | Wagon | Shuttlee 1 08-11-2002 02:42 PM
