Old 08-25-2003, 12:10 PM
topher91 topher91 is offline
Would this ECU trick work??
Hey guys I found this one:
1. Reprogramming ECU into giving you better gas milage after an upgrade
After you get a performance upgrade (i.e.. Headers, Exhaust, Intake, Etc..)
follow the following steps to reprogram your computer.
Turn on the car and warm it up (make sure that its at its normal idle)
Turn off the car an pull your ECU fuse located in the fuse box UNDER the hood
Keep fuse out for at least 5 min
Plug fuse back in and close hood
Start your car MAKING SURE NOT TO TOUCH THE GAS WHEN YOU START IT UP!!
Let the car idle (at its normal idle) for about 3-4 minutes
shut off car then restart
Thats it! Your CPU is programed to give so much air and so much gas. By
taking out the fuse you kill all power to your computer and reseting the
"program" that gives the mixture. Now by NOT TOUCHING THE GAS as you fire it
back up, it will reprogram itself to give you the best MPH as it can.
--Scott
http://www.geocities.com/civix1991/Tips_tricks.html
Now would this really work??
-Chris
1991 HONDA Civic DX Hatchback
FOR SALE!!!! PM me for details........
Old 08-25-2003, 12:41 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
it doenst work, dont bother. its all a myth
Team Lonely Drivers
Old 08-25-2003, 12:47 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
it works on the 94+ integras ... but i aint heard of anyone sucessfully doing it on a civic.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-25-2003, 01:12 PM
ED7 Drifter ED7 Drifter is offline
Send a message via AIM to ED7 Drifter
It works.
The ECU re-adapt itself to the new weather conditions.
I do it at the beginning of october and at the beginning of may.
Old 08-25-2003, 01:24 PM
ok it works when the car is cold because when the car is cold it reads from the ecu, but when the car is warm its reading from the sensors and shit so the little reprogammin u did, doesnt even matter.
once the ecu opens it doesnt matter
Team Lonely Drivers
Would this work? dgdarien Car Audio 2 05-16-2002 01:15 PM
Would This Work? Koojo Audio/Security 2 01-31-2002 03:12 AM
would this work??? lowkeyciv '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 12-13-2001 10:45 PM
Would this work on a G? endfro Cosmetics 2 08-17-2001 09:01 PM
