Old 08-25-2003, 08:12 AM
snipez's Avatar
snipez snipez is offline
engine all loud when cold
when its somewhat chilly out the engine is all loud n stuff, but when it warms up its fine. Would this be an air sensor?
Old 08-25-2003, 12:45 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
I made a post about this. What type of sound exactly do you hear? Is it a duck duck duck from under the engine cover? Cuz I only have that sound when the engine is from a cold start. If this is the sound, the sound is more noticeable in dual cam cars. When I went to a mechanic they said a valve adjustment would make the sound quieter, but wouldn't eliminate it. They think it's the rings around the pistons. That would be typical for a used sports car, since it's probaly been abused.
BTW, what kind of car is this?
Old 08-25-2003, 01:17 PM
sihondasracer's Avatar
sihondasracer sihondasracer is offline
Send a message via AIM to sihondasracer Send a message via MSN to sihondasracer
i got the same question...what motor?...um my SOHC NON-VTEC motor does it when its cold.its valve knock .this is because when the engine warms up,the metal expands there for its not knockin as much.have the valves adjusted...but then agian...who says its the valve's?...um yea same question agian what type of sound?
i live for the feeling i get when i downshift and feel the motor scream up to 8000 rpm and pull on any unsuspecting victim with the fury that an old hatchback should never have.
Old 08-25-2003, 02:12 PM
snipez's Avatar
its not a knocking sound, it just sounds like the engine is working harder than it should, if that makes any sense
btw
its a 93 grand am v6,
ps don't flame on me because i'm posting in the honda forum, it's just I never get any answers when I post in the grand am forum
Old 08-25-2003, 10:42 PM
haha i know what you mean about postin here.youll def get an answer cuz theres so many of us honda/ack ppl...haha....but sorry i cant help you unless i hear he sound...im not that good yet...sorry
Old 08-25-2003, 11:33 PM
rubix777's Avatar
maybe if you can record the sound of it, convert it to mp3, and upload it to a webpage so we can hear it.
I rarely see v6 have problems with power. You mean that kind of weak sound like when you turn on the A/C? I think having the A/C on takes off like 30 hp. And that much hp loss in 4 cyl engines are so noticeable. v6 not as noticeable.
Old 08-25-2003, 11:45 PM
snipez's Avatar
yea, power is still there, its just like a whirrin sound
Old 08-25-2003, 11:56 PM
Bambooseven's Avatar
Bambooseven Bambooseven is offline
by working harder, do you mean it sounds like the RPM's are higher at an idle from a cold start? but they aren't? My buddy's grand am did that, then we ran it into a wall. I guess our way of fixing it wouldn't work out as well for you would it? hehe
Old 08-26-2003, 12:54 PM
snipez's Avatar
no, it's not at idle. Just when I start going.
the other problem I'm currently having is the RPMS are way to high, like 4 grand.
what I mean is, when I'm getting up to 60 km/h, its taking up to 4 grand for it to finally catch that gear. and once it gets into that gear, the noise and RPMS drop and everythings fine.
Old 08-26-2003, 02:08 PM
rubix777's Avatar
is this a 5-spd or auto?
Old 08-26-2003, 02:43 PM
snipez's Avatar
Re: engine all loud when cold
auto .......
Old 08-26-2003, 05:03 PM
rubix777's Avatar
so you mean it is shifting later than it's supposed to cuz all engines will sound loud in the upper rpms.
Old 08-26-2003, 06:25 PM
snipez's Avatar
yes, it's shifting later than it should. could that be a clogged transmission filter??????
Old 08-26-2003, 09:33 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
When's the last time you changed the transmittion fluid?
Old 08-27-2003, 12:48 PM
snipez's Avatar
1 month ago
engine knocking only when cold kakakidan Neon | Plymouth Neon 3 08-03-2005 03:16 PM
tbi engine oscillating idle, when cold franklinj Suburban 3 10-30-2004 02:27 PM
engine raps on when cold start licketysplitbob Grand Prix 11 10-08-2004 09:45 AM
Engine Cranks Longer When Cold snipez Engineering/ Technical 3 09-18-2003 10:42 PM
engine all loud when its cool out snipez Grand AM 0 08-21-2003 08:37 AM
