Old 08-25-2003, 02:49 AM
Newbie 88 Newbie 88 is offline
Anyone ever seen this? Oil filter prob?
I was changing the oil in my D15B2 and when I took off the oil filter there was NO oil in it. I have never seen this before. Have you? What could the problem be and how do I fix it???
Old 08-25-2003, 09:40 AM
jusg19 jusg19 is offline
its called find the magical leak.
1) is the block covered with an oil/grease residue, if so follow it to see where the leak is.
2) check your radiator fluid and make sure its green and not like mud, if muddy its all in you radiator and your head gasket is gone.
3) it may be leaking oout your valve cover gasket
4) I'm not sure if it has an engine oil cooler, if it does, your o-rings might be gone, (I'll look more into this for sure)
5) you just ran out. so check your oil everytime you fill up with gas is a good policy. that way you have a good idea how much your losing every 300 miles.
Old 08-26-2003, 01:51 AM
There was oil in it when I started the oil change, maybe 1/2 quart low though. It had the head rebuilt 2 months ago, so new head gasket, new valve cover gasket. I can't see any leaking. Radiator fluid is clean, no problems there.
Old 08-26-2003, 02:33 AM
BullShifter's Avatar
Did the oil drip when removing the filter?
Old 08-26-2003, 04:39 AM
No dripping. There was just a little oil around the rubber seal and that was it. It looked like there might have been a teaspoon worth of oil in the filter, at most.
Anyone ever seen this? Oil filter?? Newbie 88 Engineering/ Technical 1 08-24-2003 12:50 PM
Anyone ever seen this???? thewoahna Engineering/ Technical 5 04-02-2003 10:04 PM
has anyone ever seen this model?? ayil911 General Discussion 3 01-30-2003 10:03 AM
has anyone ever seen this model?? ayil911 General Discussion 0 04-06-2002 11:45 AM
Anyone ever seen this before? Prelussion Engineering/ Technical 10 03-02-2002 07:50 PM
