Old 08-24-2003, 11:25 PM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
TPS sensor
i recently aquired a TPS sensor from a friend of mine, my car was running a little strange so i thought it might be it. so i replaced the tps with the new one, well it didnt work so i went to put mine back on, well now the car is throwing a check engine light and throwing codes 3 and 8, which is 3=manifold absolute pressure and 8=TDC, top dead center (timing) anyone know how to make my car back to normal, im reallyyyyyyyy bumbed about it.n the car is not drivable now. it pops and almosts dies now.
*TeamchokE* i love to support my boys, www.HBultimatetraining.com ,
www.chrisbrennan.com ,
www.zentraediracing.com . all my boys.
Old 08-24-2003, 11:43 PM
BullShifter's Avatar
did you reset the ECU & then check for re-coding?
Code 3 - replace map sensor
Code 8 - replace distributor or TDC sensor
Old 08-24-2003, 11:46 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Did you set the TPS with a multimeter.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-25-2003, 09:26 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Stop doing it the stupid way might help. Go buy the throttle body with the TPS attached and the factory sealed screws in place - problem solved.
If I had a dollar for every time I said this....
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-25-2003, 10:39 AM
hey dick, if i had that kind of money i might why dont you send me the money for a whole new throttle body.
Old 08-25-2003, 11:27 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: TPS sensor
eh?
Got a how-to on that? I replaced the TPS on the throttle-body for my d16y8, which hasn't been installed yet, but I just slapped it in there... So, is there something else I gotta do?
Old 08-25-2003, 04:49 PM
Setanta's Avatar
Re: TPS sensor
Wreckers maybe?
Maybe if you actually did a search on the topic then you'd see that in a number of recent threads, most people come to the same conclusion - that setting it by multimeter is near impossible and that there was a reason that Honda sealed the unit.
As for sending you the money - go get a job.
Like I said - do it properly the first time because the way you are doing it sucks.
I won't even lower myself to your childish name calling, apart than to suggest that you go buy a fucking clue
'99 PY DC2R
'85 BBS BMW E30
Old 08-25-2003, 10:42 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
Re: TPS sensor
what are the settings supposed to be?
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Impossible TPS problem entrepa Sidekick 0 10-25-2010 07:25 PM
Coolant Temp Sensor and TPS sensor problems? DAVID A SMITH Engineering/ Technical 1 06-01-2010 08:30 PM
Coolant Temp Sensor and TPS sensor problems? DAVID A SMITH Grand Prix 1 06-01-2010 04:04 PM
1998 cADILLAC dEVILLE cONCOURS,LOCATION OF IAT SENSOR, and TPS Sensor jspeigne Deville 4 06-02-2008 03:14 PM
TPS sensor bad! Throttle position sensor bratt Yukon 0 02-11-2008 05:23 PM
