Old 08-24-2003, 10:47 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
is it my distributor or sumthing????
ok i just finished the swap went to start it and it just cranks.....then checked to see if there was a spark and there wasnt.......then i feel the distributor and it was like burning hot to the touch of your finger but only on the bottom of it the top was kinda hot.....so im thinking it a bad distributor???? i dont kno what else it could be i think im going to by a new one tomorrow and if it doesnt work then im going to return it
anyone have any idea????..............thanks
Chris
Old 08-24-2003, 10:58 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
did u remember to connect the ground wires on the harness to the block? check to see if there is spark, n fuel when u turn the key do u hear the pump turn on?
Old 08-25-2003, 09:32 AM
Re: is it my distributor or sumthing????
i am almost positive that i connected to ground to the block and im sure that the pumps going on cause i can smell gas just alil but its not leaking i cant go and check now...im at school but ill look right when i get home i think its the distributor because it got like really hot just from cranking and i didnt even crank it that much.......im nto sure i think im goign to buy a new one and if it doesnt work just return it......
Old 08-25-2003, 12:26 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
the dist getting that hot could be a ground problem. because one time a friend of mines truck the fuel pump always got really hot, turned out it was loose ground
Team Lonely Drivers
Old 08-25-2003, 03:18 PM
i kno that all the ground wires are hooked up so its not that and i just changed the plug wires and its not that i think im goign to try a new distributor......what would the number be for it or what car????
thanks Chris
95 Caprice SW change distributor help (pulley removal) bigwar Caprice 11 02-26-2011 10:19 PM
2002 Distributor Install Procedure wmako M Bodies 2 02-02-2010 09:16 PM
sumthing wrong with my diff? 4G63_Spyder Off-Topic 5 05-12-2004 09:48 PM
sumthing is hitting my right foot? stolen Sn 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 03-12-2004 02:37 PM
decided to do sumthing different in the back of my rex CRXsk8er '88 - '91 Civic | CRX | Wagon | Shuttlee 16 05-18-2003 02:38 PM
