Old 08-24-2003, 09:46 PM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
cv joint help?
hey i was wondering if anyone has done a faq about cv joints, i haven't done it before and i can't afford to do it at a shop so please help i need to get it done in one day because i only get one day off from work a week.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 08-24-2003, 10:24 PM
BullShifter's Avatar
Just replace the axle with a reman. piece. Should only take about 1hr to replace - faster if you have done it before.
Old 08-24-2003, 10:38 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
dont be scared to do stuff yourself cuz if you dont try you'll never learn, its not that hard, get a book and take your time, and the next time it will be so easy
2002 Acura TL Type S
1991 Honda Crx Si
Old 08-26-2003, 02:56 PM
chocolate
thanx, for the boost guys i'll post my results morrow.
Old 08-26-2003, 10:43 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
man when i changed my cv boot, it took me like 3 hours cause first i changed the outer ones, then i realized u change the inner ones when u change the outer ones because they come off the outer side. so i had to take off the boot again and pull hte innner ones out and change them and put hte outer ones back on. i used like so much of those clips that day. like he said, do it yourself or youll never learn, i found it by doing it
Team Lonely Drivers
Old 08-27-2003, 12:01 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
http://www.fourthgenhatch.com/axle.html
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-27-2003, 08:08 PM
ok to anyone who's still online i can't get my new axel into the trannie, any ideas?
Old 08-27-2003, 08:25 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
There are 2 kinds of axles for 4th gen civics, some have 23 splines, some have 26. Don't quote me on this, but I think the civics with the 4 spd manual trans had the 23 spline ones. But you need to mark one on the old axle (as a starting point), and count how many are there, and you need to count how many are there are the new axle.
If they are the same, and you are just having trouble getting it to snap in, start the one end in the trans, and the other end in the wheel assembly, and use the wheel part like a slidehammer to pop it in place. MAKE SURE you have the splines all lined up before you do this! If everything is lined up, doing that doesn't hurt anything, and could save you alot of effort.
Hope something there helped.
Old 08-27-2003, 09:30 PM
well thanx for the tip but i changed my trannie myself so i know i have the right spindle # and even double checked before i came back. i do appretiate the help though but now i have a new problem i can't get it into the hub or wheel assembly i think they would be the same thing. it's really pissing me off any ideas.
Old 08-27-2003, 09:40 PM
The transmission side (inner splines) of all the axles were the same. However the hub side (outer splines) of the HF and STD was 23, while all others were 26.
To get the axle into the tranny you have to get it past the snap ring. To do this all you need is one strong blow to the axle. What I did is make sure the axle is as straight as it can be, than with a the top of a rubber mallet in the palm of my hand just punch the back of the axle and the force is enough to seat the axle in. Than for the hub side just pull on what you have to to get the clearance and than maybe turn the hub by the wheel stud to line up the splines.
Old 08-27-2003, 10:24 PM
thanx for the advice i read your 'how to' to get it into my trannie but i just found out that the people i had put in my dx trannie gave me a half 26 spindle half 23 spindle axel instead of changing my hub. that really pisses me off but they did tell me they didn't change the hub and i did ask them to do it in the cheepest way possible, now. is it possible to get a 23-26 spindle axel or do i just have to change my hub tomorrow morning b4 work. they found someone to cover for me from another store but i want to get in there as soon as possible... any advice?
Old 08-27-2003, 10:26 PM
hey could i also get a 2g integra hub just wondering so i have more options to look for at the junkyard tomorrow.
Old 08-27-2003, 10:53 PM
zipidy doo i can see swirls or color and everything i look at is swerling , damn it's fun halucinating when you crave nicoteen. i prolly can't spell either but i am just being silly....... ow, my head hurts
Old 08-28-2003, 12:16 AM
How can you have a half 23 and half 26 spine axle? The Inner splines are all the same for all the Honda axles. The outsides were either 23 for the HF or STD or 26 for the rest of them. Count the number of splines your hub has. Use axles with that number of outer splines.
Old 08-28-2003, 03:14 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
Re: cv joint help?
hey i have to change my cv boot too it ripped, but anyway im not understanding what u mean why would u have to change the inner ones if they are the ones on the inside, it would seem the outter one would come off first, i have no experience with axels so thats why i sound like a dumb ass, so maybe the boot comes off from the more inside part of the axel, i dont know, did u mean u had to buy an inner boot as well or just had to take it off, also what clips are you talking about????
Keep it real, and share the knowledge.....
Say NO to Primer!!
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
92 prizm CV JOINT HELP PLEASE! cpowers General Discussion 7 06-22-2005 08:02 AM
03 4x4 ram u-joint help request hemipower Ram Pickup | Ram SRT10 4 07-21-2004 09:20 AM
1992 f-150 super cab Ball Joints HELP!!!!! 94gpse F Series 1 04-20-2004 08:47 PM
Ball Joint help Sally2Trees Crown Victoria 2 02-20-2004 04:45 PM
