Old 08-24-2003, 08:14 PM
blade34609's Avatar
blade34609 blade34609 is offline
Check Engine Light
Hi,
My check engine light still wont do away.
I used to have a battery light and i fixed it.
Put a new wiring harness in.
The problem is when you first start the car it will idle at like 900-1000 RPM then gradually move up to 1200 and stay there.
I have all the hoses in the right places.
Could it be my throttle postion sensor on the manifold?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-24-2003, 08:17 PM
BullShifter's Avatar
Which code is it? Pull back carpet in passenge foot area - turn ignition - count # of flashes? That will be of great assistance.
Old 08-24-2003, 08:24 PM
Redline_civic91 Redline_civic91 is offline
Send a message via Yahoo to Redline_civic91
what code is it throwing, it very well might be your cold idle temperture valve. i think thats what its called i cant remember but mine was idling at 1200 i left it alone then it just worked its way to idling at around 2500 rpms. took it to my mechanic took about 15 min. to adjust.
91 civic b20/vtec=sold
95 acura integra=sold
02 chevy silverado=totalled
95 honda accord=please i hope nothing happens to this!
Old 08-25-2003, 02:55 PM
blade34609's Avatar
I did this with the key in the ignition on the on position.
Car was not running I dont think this makes a difference.
Ok,
Well I got
7 flashes: Throttle Angle (its idles at 1200)
10 flashes: Intake Air Temp (my aftermaket short ram, correct?)
13 flashes: Atmospheric Temp (no clue what it means)
6 flashes: Coolant Temp (I think im low on coolant)
The one that catches my biggest attention is the throttle angle.
If you could help it would be greatly appreciated.
Thanks A lot.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-26-2003, 03:47 PM
blade34609's Avatar
Anyone got any ideas?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-26-2003, 10:50 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
umm maybe the throttle cable is too tight
Team Lonely Drivers
