Old 08-24-2003, 05:08 PM
taylor2527 taylor2527 is offline
aftermarket cd deck install. help please
ok so heres the deal guys, i own a 94 camaro z28. i bought a kenwood mp-522 deck. i have arranged all the wires correctly (i think) and this is how it works. it turns on and i can listen to the radio just fine, but if i want to listen to a cd i can tell that it is reading the disc and that it is playing (the name of the song scrolls accross and it shows the duration of the song and so fourth) BUT I CANNOT hear it, there is no sound coming out of my speakers. but the radio works just fine. does anybody know a solution for this problem? thanks
Old 08-24-2003, 06:34 PM
petereggy petereggy is offline
i think u need to go to circut city or wherever you got it to get them to help you cause the deck could be defective
Old 08-24-2003, 10:21 PM
IthePeople IthePeople is offline
Send a message via ICQ to IthePeople
are you running an external amp?
go big or go home
fuck imports
Old 08-25-2003, 11:05 AM
if you are running an external amp with subs and all that you need to have rca cables hooked up from your deck to the amp, otherwise your cd player wont put any music to your amp, this sounds like your problem because in this case, the radio will work (and power will goto the subs) but when you switch over to a cd nothing will happen because there is no info going to the amp.
if this is your problem then hook up your rca jacks, there should be plugs on the back of your deck where they go, if they are not there (like my deck) you can buy plugs from your local stereo guy and they get wired into your rear speakers,
good luck
go big or go home
fuck imports
Old 08-25-2003, 03:56 PM
also with the amp you should make sure your bus line is hooked up as well and make sure you have 2 sets of rca cables comming off your amp if your running 2 subs if not you only need 1 set
Old 08-25-2003, 04:29 PM
u only need 1 set of rca cables per amp however many subs, speakers ect u choose to put on the amp is irrevelant, 1 set of rca cables comes with 2 jacks (one should be white and the other should be red) and they hook into the back of the deck where there should be two jacks also
go big or go home
fuck imports
Old 08-26-2003, 02:28 AM
yah that and then there is 2 sets of holes on the amp one red and white for left side another for the right you need rca cable splitters to use 2 sides of the amp
Old 08-26-2003, 09:22 AM
??? none of my amps have this.... im lost
do u mean the high input feeds?
go big or go home
fuck imports
Old 08-26-2003, 03:47 PM
no
my amp has 4 rca inlets on it 2 for the right side 2 for the left (when i say 2 i mean one red and one right) and when i only had one set hooked up one sub worked
