Old 08-24-2003, 12:08 PM
blade34609's Avatar
blade34609 blade34609 is offline
Cooling fan wont turn on
hi,
My engine cooling fan wont turn on at all.
I let the car idle for awhile and when the temp gauge gets to almost the redline it still wont turn on.
Coolant starts bubling in the coolant resevior.
The only way im keeping it cool now is by just driving and letting the radiator cool it.
I checked the fuse and its not blown.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-24-2003, 12:16 PM
BullShifter's Avatar
1. Fan Relay
2. Coolant temp switch
3. Fan motor
Those are the 1st 3 things I would check.
Old 08-24-2003, 12:30 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
if worse comes to worse just rewire your coolant fan to a toggle switch
KoRnSaQ
Old 08-24-2003, 08:20 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
first test the fan motor, take it out and hook it up to a 12v power source, if it spins then the motors good. if its good, its probably the relay because those are the ones that usually go, not the coolant temp switch. but both could use a replacement anyways so if you replace the relay and thats not it, it was good u replaced it anyways because its old
Team Lonely Drivers
Old 08-25-2003, 12:50 AM
jusg19 jusg19 is offline
check the fan plug....sometimes it gets corroded... just check it on a 12v souce....toggle is a good idea.
cooling fans wont turn off Xraller Beetle - New/New Beetle Convertible 10 02-06-2010 04:16 PM
cooling fan wont turn off. moms van Villager 1 11-26-2008 03:41 PM
1998 Chrysler T&C minivan both cooling fans wont turn off waltham41 Caravan | Voyager 11 08-05-2007 07:44 PM
cooling fan wont turn on... jackmalone2001 Camaro Discussions 12 07-15-2005 09:52 PM
cooling fan wont turn on Hefdog14 Cavalier 4 07-04-2004 08:49 PM
